tim wrote in post #3605511
I'm looking at the instructions for the latest version and the xml file has either changed its name or you're using the wrong filename. Also the instructions say to put the high res images into an "image" directory (you have them in the same directory as the xml file) and the thumbnails in a "thumbs" directory. Perhaps you should upgrade to the latest version and do things like it suggests? I've just downloaded SimpleViewer and worked this out by looking at their example
I have used it in the past but i've gone away from flash myself.
Hey Tim,
I don't think I'm using the wrong filename because I never changed it to begin with. But just in case I were, I renamed it how you typed it out earlier. Even less showed up when I did that so I moved it back to the original way. Also, I've done things the suggested way, as well. I uploaded all the thumbs and high res images to seperate folders. I've also upgraded to the latest version (actually I downloaded the newest version initially but downloaded the updated version just in case). When I open the index.html file in the gallery folder on my desktop, it shows up exactly as planned. It's just when I upload the whole thing to my website that I have the problem. I am definitely running in circles, that's for sure. Even if you can't figure out how I've gone lost here, thanks for the effort
