Thread started 25 Jul 2007 (Wednesday) 04:43
Best Free Macro solution
th256
Jul 25, 2007 04:43 |  #1
What is the best free (or close) macro solution?
in terms of magnification and in term of quality
reversing the lens ? moving the lens forward ? other ?
--------Tony
Sathi
Jul 25, 2007 12:01 |  #2
Here is a method with a pringles can
http://www.photocritic​.org …-photography-on-a-budget/ (external link)
Only thing free I can think of is cropping.
20d / Tamron 28-75 2.8 / Canon 10-22 / Canon 100mm macro
LordV
Jul 25, 2007 13:19 |  #3
th256 wrote in post #3606948 (external link)
First one would be reversing a small lens onto a larger focal length lens- assuming you have the lenses you can make a suitable connection tube or buy a male to male reversing ring.
Second would be a camera body reversing ring - fairly cheap (around £10 on ebay).
Brian V.
Macro Hints and tips
Action_Man
Jul 25, 2007 13:34 |  #4
Yes what the others have said - i use the reversing method and you can buy cheap lenses that have the correct filter thread - you can buy any manufactures lenses to reverse - i prefer to use Olympus lenses as they seem to be the cheapest :D ...
th256
Jul 26, 2007 02:31 |  #5
Thanks guys for the info but still the main question is
which can achieve better magnification and which better quality?
--------Tony
LordV
Jul 26, 2007 03:03 |  #6
th256 wrote in post #3612521 (external link)
Depends on what lenses you actually have. Suspect the image quality would be good from any of the methods- probably best if you used a prime lens around 50mm with a set of ext tubes. The main problem with many of these is how easy is it to take a shot.
Both a reversed lens on another lens or a lens on auto ext tubes is easy.
A reversed lens on the camera body or the use of a lens on non- auto ext tubes requires you to stop down the lens first (assuming it's an AF lens without manual aperture control) by attaching it directly to the camera- selecting the aperture you want and then removing the lens whilst keeping the DOF preview button depressed. This will set the aperture but you then end up with a slightly dim viewfinder.
Brian V.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Jul 27, 2007 10:17 |  #7
I just created a macro gallery to store my kit lens macro shots, it does quite well reversed with a $14 metal ring.
http://snapintime.smug​mug.com/gallery/321132​2#177187379 (external link)
For example, I call this "Wash Your Fruit" (yeech).
1,844 views & 0 likes for this thread, 5 members have posted to it.
2712 guests, 167 members online
