nutsnbolts wrote in post #3609086
I haven't shot in RAW yet but I'm about to give that a try. Although I don't understand the actual differences other than hearing from people saying that RAW comes out better and more editing capabilities? I still don't understand because aren't we making edits now on the JPEG file? *shrug*
example, some zoo picture of a giraffe somewhere here I thought was nice and beautiful done, then again someone responded that there is a bluish tint and it should be warmed up a bit....I'm like huh?
The "eye" part is acquired, and subjective. What one person may love, may not do anything for the next guy. Also, monitor calibration could affect whether, for example, someone else saw a blue tint and you did not.
There's a number of good threads on RAW here, so I won't attempt to duplicate their efforts but heres the "nutsnbolts"
In LR, you can edit either RAW or Jpeg. If working with RAW, it does not convert it to jpeg first... you are actually working WITH the RAW file (ok, a rendering of the RAW file) until you export it to another file format.
You also have more latitude in edits with RAW before artifacts start showing up in the image... more bit depth: meaning more color information, etc to work with than in the jpeg,. Also, WB can be changed in RAW without introducing artifacts, whereas its "cooked" into the jpeg. All of this likely also means more work on your part... YOU are doing what the chip in your camera usually does on the fly for a jpeg image... it may take longer, but you get to choose every setting exactly as you want it (and go back and try it a different way, if desired.)
