After reading through several post about some people calibrating there lenses to the MKIII i decided to see if there was any difference between my two cameras and lenses.
After setting up a tripod and doing some tests between the MKIII and MKII N i have found that with no calibration adjustment to the MKIII i get the same results as the MKII N. None of my lenses have been sent to Canon in the past for calibration and give the same results on both bodies.
Has anyone else carried out a comparison between both cameras on single shot and what have been your results out of intrest as i seem to remember reading some post where people have found that they have needed to calibrate there MKIII compared to there original cameras.
What method did you use to test the calibration?
