Thread started 27 Jul 2007 (Friday) 18:28
Working with 2 580EX's
jerrybsmith
Jul 27, 2007 18:28 |  #1
I have 2 580EX's and I need instructions on how to set them to work as follows:
1. Flash on camera fires / flash off camera fires.
2. Flash on camera does not fire / flash off camera fires.
www.jerrybsmith.com (external link)
SIMPLEPHOTOLT
Jul 27, 2007 19:49 |  #2
I think I know the answer to number 1:
You set your on camera flash to master and the other one to slave. (look at the manual for the options. you can choose A:A, A:B and such ... I forgot). Leave your flash at ETTL mode. Then when the flash on the camera fire, it will also trigger the off camera to fire.
For number two, try setting the custom function to not fire and see if it work. But I think it won't work though because as far as I know, canon flash works on the basis of light triggering, not radio signal (?? someone please correct me if I'm wrong). Therefore, if the master does not fire, the slave won't fire either.
Hope this helps (even if just a little ):)
Canon 30D, 5D, Mk IV
Canon 100mm 2.8 Macro, Canon 18-55mm kit lens (for sale), Canon 50mm 1.8 II, Canon 75-300 4-5.6 II, Canon 24-105 f.4L, Canon 17-55mmm f/2.8IS, 85mm 1.8, 70-200L 2.8 IS Canon, Sigma 12-24mm EX, Kenko 25mm ET, Kenko 1.4x Pro 300DG
430 EX, Canon 580EX.
wakko
not a real Aussie
Jul 27, 2007 20:39 |  #3
jerrybsmith wrote in post #3622013 (external link)
I see you have an ST-E2.
I don't know if you can make the flash on camera 'not' fire... but you could use your ST-E2 to fire the remote flash only. you probably figured that ;)
Feng
Using a 5DII + Other Bits & Pieces
Brisbane Coffee Club - Everything From Shutters to Cuppas... Take 2
**** POTNAC Servaas Group Buy - Mark III - Arrived & Packing! ****
jerrybsmith
Jul 28, 2007 16:01 |  #4
You are right Wakko. I use the ST-E2 all the time but would like to explore the capabilities of working with two 580EX's.
wimg
Jul 28, 2007 16:31 |  #5
jerrybsmith wrote in post #3626203 (external link)
You can't work with two flashes, firing one only, if the one on camera is supposed to trigger the other one, off camera, unfortunately.
So either you'll have to use the ST-E2, to trigger a remote flash, trigger only a single flash with the ST-E2, or use a very long extension cord :).
For two flashes, you can use both as remote flashes with the ST-E2, use one connected to the camera to trigger the other, or use a divider to connect more than 1 flash to the camera.
In short, it means that with
you can use the on camera flash to trigger the other one set to slave
can only be done by removing the flash on camera, substituting it for the ST-E2, or connecting the off camera flash by a long flash extension cable.
Kind regards, Wim
Ephemeral
Jul 28, 2007 16:37 as a reply to  @ wimg's post |  #6
Mmmm...I'm sure I've got my 580 to trigger my 430 without the 580 flashing.
...let me check.
Canon 5D + Grip | 85mm L f/1.2 | 17-40mm L f/4.0 | [COLOR=Silver]24-70mm L f/2.8 |[COLOR=Black] 70-200mm f/2.8 L IS | Speedlite 580EX & 430EX | Manfrotto 190Pro + 488RC2
ephemeral.smugmug.com (external link)
Ephemeral
Jul 28, 2007 16:50 as a reply to  @ Ephemeral's post |  #7
Here's a pic of my 430 being trigged from my 580.
P. 36 of my manual shows me how to disable the master to not fire the flash.
crackaonrice
Jul 28, 2007 17:03 |  #8
How do you prevent the 580 from firing COMPLETELY though. Isn't it set to always fire a preflash or comm. flash or something?
Why does everybody list their gear here? :rolleyes:
http://www.jkan.net (external link)
pagnamenta
Jul 28, 2007 17:35 |  #9
I did some product photography today with two 580's, one on camera and one in a home made soft box, and it's impossible to only have the slave fire. I've tried every setting and if the main flash on camera doesn't fire, neither does the slave.
Canon 1D3, Sigma 70-200 f2.8, Sigma 120-300 f2.8 (sale), 1.4x converter, 580EX.
Ephemeral
Jul 28, 2007 18:19 |  #10
crackaonrice wrote in post #3626432 (external link)
Ahhh....in that case. No, the 580 will always pre-flash. :(
crackaonrice
Jul 29, 2007 11:24 |  #11
Ephemeral wrote in post #3626715 (external link)
Phew! Good!...well, not good for us in general...but good for me because i spent like 2 hours trying to get that to work and didn't get the results you claimed earlier. :D
1,369 views & 0 likes for this thread, 7 members have posted to it.
978 guests, 122 members online
