Thread started 27 Jul 2007 (Friday) 19:32
MP-E 65mm Test Drive - Jumping spider at 7x!!!!
sirsloop
BigFoot
Jul 27, 2007 19:32 |  #1
Ok, so first things first... this lens is like outrageously hard to use anything over like 3x. I'm talkin your entire frame is taken up by like a 2x3mm area at 7x. (literally). At any rate...I borrowed the lens w/ twin flash setup just to mess around over the weekend. Anyways... 65mm MP-E plus a 1.4x teleconverter gets your 7x!
So first off... this is what we are shooting at. This is a TINY jumping spider which is about as big as a dime is thick. Its probably like 1mm x 1mm... like a touch larger than the "S" in states on the dime. I barely didnt see it when I walked inside but it happened to move as I was opening my door. BTW, this was taken with my 35/2 and cropped down just to show size reference.
I think this is about 3x-ish with the 65mm without the TC, uncropped.
Then it gets hairy...lol. The little guy stopped moving around so I could get a clean shot of him. UNCROPPED!!
and another 7x uncropped...
Now i'm not sure why these look a bit soft. I was shooting f/16 (completely stopped down) with the 65mm. I guess at this level you are really pushing the resolution limits of the lens? I mean this is just outrageously small blown up to nearly the size of a XTi sensor...lol. The bottom right is a bit soft cause there was web there... but the rest was clean
no gear List
Samdiver74
Jul 27, 2007 21:01 |  #2
Pretty impressive shots Sirsloop, So what is your overall impression of the MPE compared to the other techniques such as reversed 50mm and 28mm.
To me the fact that it is one package appeals to me, not to mention the MT24EX would be another must have.
I see what you mean about the image quality at 7X do you think it could be because of the TC and the fact you were at f/16 what if you back it off to f/8 to f/11 do you think that would help, of just the fact that MPE isn't designed to be used with a TC.
What if you took a picture with just the MPE at 5X and then cropped the image to similar size of 7X do you think this would help also, I'm seriously thinking the TC has a lot to do with the image quality
Let us know.
Allan
7D, 7DII, 10-22mm, 100-400, 50mm 1.4, MP-E 65mm, Sigma 150-600mm Sport, TC-80N3, 580EX, 580EX II ST-E2, OC-E2, 3021 BPro, 488RC4, Kenko EF/EFS ext tubes, The Ultimate lightbox system & Delta flip flash bracket & various lighting accessories.
http://allanmorris​.my​portfolio.com/ (external link)
sirsloop
BigFoot
Jul 27, 2007 23:09 |  #3
well the 65mm is pretty similar to how you would use a reversed 28. You don't have AF... you use your distance for focusing. Obviously the 65 is gonna be more versatile cause it cna vary from 1-5x where as a reversed lens is fixed. The twin flash setup is also far superior to a bracket with a 580 on it. The one problem I did have is that at 4-5x the focus distance is like 1/8" past the edge of the flash ring. You are literally putting the lens 1.6" away from your object!! Very very very close working distances.
I think the spider lives there... i'll take off the TC and try again tomorrow and we'll see!
no gear List
Leorooster
Jul 28, 2007 00:29 |  #4
The 7x images are definitely a bit soft. I did a similar test and had a very acceptable result. See HERE. I used f/14 which is not far off from f/16. What TC did you use? I used a Canon 1.4xTC. :)
Canon 1DMarkIII :shock: | Canon 5DII :p | Fujifilm Finepix F30
Glasses & Goodies
LordV
Jul 28, 2007 02:04 |  #5
Good shots- As Adrian says the pics are a bit soft- comination of the TC and the fairly marked diffraction softening using F16 at 5X. I'm normally down around F6.3 at 5X.
brian V.
Macro Hints and tips
sirsloop
BigFoot
Jul 28, 2007 10:55 |  #6
5x, no TC, f/7.1... a bit sharper but crazy small DOF...
no gear List
bob393
Jul 28, 2007 11:42 |  #7
Wow unreal.
The equipment list:
20D, EF-S IS 17-85mm with hood and filters, EP-EX15, Grip BG-E2,
4 2GB SanDisk EXtream III CF cards, Dell Inspiron,
Manfrotto 3205 Tripod, Lowepro Orion AW backpack,
PowerShot A620, And an F1 system in it's case collecting dust!
Samdiver74
Jul 28, 2007 11:48 as a reply to  @ bob393's post |  #8
Sirsloop
That looks much better, what about bumping the aperture down to f/9 or f/11 and see what that gets you. But I would say that pic is much better even though the DOF is so shallow.
Allan
sirsloop
BigFoot
Jul 28, 2007 11:54 |  #9
I tried going higher but like LordV mentioned, you get a lot of diffraction out of the lens when stop it way down. Just the nature of the beast it seems. This is where focus stacking comes into play...
no gear List
sirsloop
BigFoot
Jul 28, 2007 12:27 |  #10
ok... if this wasnt crazy enough... here's something that may peak all of your interest!!
($900 and change) MP-E 65mm vs ($24.99 - YES!) Quantaray 28mm/2.8 reversed !!
uncropped, f/5.6, 28mm reversed
cropped !!!!!!!!!!!!!!!
IMAGE: http://www.dslr-forum.de/images/smilies/eek.gif
To be completely honest, even though I have to hold the ring flash up and push the aperture lever over manually, the 28mm was MUCH easier to work with. Well, this is kind apples and oranges seeing as though the 28 reversed only gets like ~3x zoom. With the MP-E you are always tempted to crank it down to 5x. The difference between 3x and 5x as far as working distance and usability is pretty amazing.
no gear List
Samdiver74
Jul 28, 2007 12:52 as a reply to  @ sirsloop's post |  #11
Wow what a difference, that is pretty significant. As I said the only difference I would see about owning the MP-E would be just the convenience of being able to go from 1X to 5X with the same lens and the fact that the Aperture etc is controlled via the camera.
Thanks for the comparison Sirsloop.
Allan
Leorooster
Jul 28, 2007 12:55 |  #12
Samdiver74 wrote in post #3625568 (external link)
............... As I said the only difference I would see about owning the MP-E would be just the convenience of being able to go from 1X to 5X with the same lens and the fact that the Aperture etc is controlled via the camera...............
That's what you pay the high price for. Whether it's worth the money, it's just personal preference. To me, the answer is yes and I'm very happy with my choice :) Good luck ;)
Glasses & Goodies
Action_Man
Jul 28, 2007 13:01 |  #13
You can add tubes with a reversed lens - i do it with my 28mm macro lens - i take the glass out of filters and use those - in total i have about 36mm worth at the moment :) ...
sirsloop
BigFoot
Jul 31, 2007 00:21 |  #14
hmm... never tried DIYing tubes on a reversed lens. I'm assuming it behaves the same as regular tubes and decreases the min. focus distance?? With this 28 it already pretty darn close...
no gear List
macro ­ junkie
Jul 31, 2007 03:29 as a reply to  @ sirsloop's post |  #15
when i bought my mpe65- it says dont add any tubes on it?
Uk prayingmantis forum - http://www.dragonscres​t.co.uk/forums/index.p​hp (external link)
My flickr gallery -http://www.flickr.com/​photos/hooked_on_macro​/ (external link)
DA Gallery where i sell prints - http://macrojunkie.dev​iantart.com/ (external link)
MPE-65MM - MT-24EX Twin Macro Flash (diffused with 2 X Gary Fong Puffer diffuser)
EF-S 60mm f2.8 USM - 430ex (diffused with lumeriqest soft box)
1,928 views & 0 likes for this thread, 7 members have posted to it.
2817 guests, 164 members online
