Thread started 28 Jul 2007 (Saturday) 11:14
Trying to stitch two images on hugin, but I get obvious seam to the sky :(
jylitalo
Joined Mar 2004
Jul 28, 2007 11:14 |  #1
I've used hugin in three periods: early experimenting in 2004, while I was still playing with Canon G3, quick test in 2006 to see if things have improved and today.
Todays experiment (check end of message for images) shows same problems that I faced in 2006. When I try to combine just couple images which has been taken on 20D with manual settings (1/640s, f8, cloudy WB), I still get obvious seam to the sky, when I combine those images.
Images were shot in raw, but all known modifiers in Bibble turned off (autolevels, highlight recovery, fill light were off, wb, levels, curves, etc. were not modified).
One obvious candidate to blame would be the lens, but Canon EF 17-40/4L lens is supposed to be good at what it does and same goes for EW-83DII hood and Hoya Pro1 Circular polarizer that I had on lens, while taking those images.
Any ideas why I can't handle as simple task as this without obvious seams on sky part of panorama? If I could make this work, I could sell my UWA lens and start doing panoramas instead, but current results out of hugin can't compete with what I get from 20D + Tokina's 12-24/4.
Anyway: here is the panorama that I was able to produce:
http://www.flickr.com/​photos/jylitalo/928323​421/ (external link)
- Juha - ylitalot.com (blog (external link), portfolio (external link), gear list (external link), etc.)
rammy
Joined Oct 2004
Jul 28, 2007 11:21 |  #2
jylitalo wrote in post #3625214 (external link)
.. and Hoya Pro1 Circular polarizer that I had on lens, while taking those images.
This is your problem. The Circular Polariser changes the saturation in the sky (polarisers the light) as you turn. Never put a CP on the lens when taking a pano otherwise you will need to use the clone tool to blend in the seams manually.
Gear | Surrey Wedding Photographer (external link) | Surrey Wedding Photographer Blog (external link) | London Architecture Photographer (external link)
Cubix ­ Rube
Joined Jun 2005
Jul 28, 2007 13:17 |  #3
My thoughts exactly, rammy...
Upside the head...A place where nothing good ever happens.
My stuff: 5DII, 20D, kit lens, Tamron 17-50, Canon 70-300 USM IS, 50 f/1.8, 580 EX, Lumiquest 80/20 flash bounce, a few filters, manfroto tripod with ball head. Pathetic Flickr gallery, (external link)Smugmug site (external link)
howzitboy
Jul 29, 2007 03:51 |  #4
u can try to adjust one of the pictures shots with hue/saturation till they match. then merge using your pano program.
http://onehourwedding.​blogspot.com/ (external link)
weka2000
Is that a 300mm in your pocket?
Gallery: 144 photos
Jul 29, 2007 04:15 |  #5
rammy wrote in post #3625239 (external link)
Yep. Always take CP off when doing panos. I learnt this the hard way.
https://tonysearle.co.​nz (external link)
1,628 views & 0 likes for this thread, 5 members have posted to it.
1739 guests, 172 members online
