Thread started 29 Jul 2007 (Sunday) 10:01
5D lenses??
Ferosso
Jul 29, 2007 10:01 |  #1
Hello POTN!
I've been thinking of getting myself an EOS 5D, but I've heard, that some lenses that fits on a 350D (my current camera) won't fit on the 5D!? Can someone comfirm that?
And if you also could tell me if the lenses i already have, will fit on the 5D:
Canon EF 50 mm f: 1,8 II
Canon EF-L 70-200 mm f: 4,0 USM
Canon 18-55 mm kit lens
So will they fit on a 5D?
Thanks in advance!
johneo
Joined Aug 2003
Jul 29, 2007 10:06 |  #2
The Canon 5D will take the Canon EF lenses but NOT the EF-S lenses. Your kit lens won't fit.
2 - 5DMKII's, Powershot SX 150 IS
7D, 5D, IR/5D, 10D, IR/10D, Elan 7NE
17-40 L, 24-70 L, 70-200 f/2.8 L IS, 100-400 L IS,
TS-E 24 f/3.5 L, 28-135 IS (x2), 50 f/1.8, 85 f/1.8 550EX, 430EX
40mm pancake
Ferosso
Jul 29, 2007 10:12 |  #3
Oh okay, so the kit lens is the only that won't fit?
johneo
Joined Aug 2003
Jul 29, 2007 10:17 |  #4
Ferosso wrote in post #3629639 (external link)
Right, it won't fit. Others on POTN have said they can be modified to fit but I can't help you there.
40mm pancake
jdizzle
Darth Noink
Jul 29, 2007 10:21 |  #5
The 50 and the 70-200 will fit no problem. If you are going with the 5D, I would suggest getting a Canon 17-40 f/4 L which is a good UWA for the 5D. That pretty much covers the range you have( 17mm-200mm). Hope that helps.
davesrose
Title Fairy still hasn't visited me!
Jul 29, 2007 10:30 |  #6
johneo wrote in post #3629653 (external link)
IMO, it wouldn't even be worth it to try to modify a EF-S lens to fit a FF. Assuming you get alright optics that doesn't leave bad vignetting on a FF, the image quality is still going to be less then a normal kit lens.
Canon 5D mk IV
EF 135mm 2.0L, EF 70-200mm 2.8L IS II, EF 24-70 2.8L II, EF 50mm 1.4, EF 100mm 2.8L Macro, EF 16-35mm 4L IS, Sigma 150-600mm C, 580EX, 600EX-RT, MeFoto Globetrotter tripod, grips, Black Rapid RS-7, CAMS plate and strap system, Lowepro Flipside 500 AW, and a few other things...
smugmug (external link)
Ferosso
Jul 29, 2007 10:33 |  #7
Thanks! If it's only the kit lens, I won't mind. The only reason why i haven't gotten rid of that, is because i dont have a wideangle lens yet :D but thanks guys!
JohnJ80
Jul 29, 2007 10:55 |  #8
Correct - all your lenses except the kit would work.
Why in heaven's name would you want to use the kit lens on a 5D?! The 5D tends to be tough on lenses - you need to put good glass in front of it because it will point up the problems quickly. The kit lens would be awful plus it would vignette like crazy (smaller image circle).
J.
Obsessive Gear List
"It isn't what you don't know that gets you in trouble; it's what you know for sure that isn't so." - Mark Twain
johneo
Joined Aug 2003
Jul 29, 2007 11:12 |  #9
davesrose wrote in post #3629691 (external link)
I never gave the FF a thought as I believe others were talking about modifying them for a crop camera.
Personally, I wouldn't buy an EF-S lens (not that my 10D would be able to use it anyway) even if my camera took them in the event somewhere in the future I wanted to upgrade to something that doesn't take the EF-S lenses, including the 5D.
40mm pancake
1,313 views & 0 likes for this thread
5D lenses??
Latest registered member is zhopp
984 guests, 243 members online
