Thread started 29 Jul 2007 (Sunday) 19:32
CS3 Border action with EXIF
forno
Jul 29, 2007 19:32 |  #1
Well I have searched and searched but to no avail
What I am after is a simple border large black edge with a finer white line between the black edge and the pic PLUS EXIF belwo the pic
Anyone got one??
Canon 350D -EF-S 10-22 l EF-S 17-55 l EF 50 f/1.8 l EF 70-200 2.8 IS l 430EX l
Fornography (external link)
tim
Light Bringer
Jul 29, 2007 21:10 |  #2
Mike's Framer - cheap and easy. Search for it here or on google.
forno
Jul 29, 2007 21:18 |  #3
Cheers Tim,
Do you know if there is the option for simple borders as I described??
I really have now desire for the example shown
This is the style of border I want, I could never get the EXIF though
IMAGE: http://img209.imageshack.us/img209/6389/img2577rb3.jpg
bckane
Jul 29, 2007 21:21 |  #4
Mikes Framer
http://homepage.ntlwor​ld.com/pooternerds/Fra​mer/index.html (external link)
Brian
Canon 7D-40D gripped | EF 24-105mmL | EF 100mm | EF 28-135mm | EF 70-200 F/4L | EF 135 F/2L | Sigma 17-70mm | EF 50mm 1.8 | Tokina 11-16mm | Speedlite 430EX
| Bogen 3265 | Manfrotto 055xprob and Manfrotto 488RC2 | Katz Eye Optics | Sigma 70-200mm F2.8 EX DG | ZERO Balance check book |
forno
Jul 29, 2007 22:45 |  #5
Nearly but not quite:confused:
Wish I knew how to use Photoshop properly:(
mickle
Joined Aug 2004
Jul 30, 2007 07:18 |  #6
Mikes Framer.
Link in sig.
Mike
Visit Mikes Scripts & Actions (external link) for:
Photoshop framing scripts for CS & CS2 & CS3
Framing Script for Photoshop 7 & CS
Dynamic Velvia script for CS & CS2
Framer Action Set for PS7
Framer Action Set for PS Elements
Mikes Framer thread
EOS_JD
Jul 30, 2007 07:48 |  #7
If you use photoshop it's very easy to do this.
open the image and save it as a new image (so you don't save over the original).
Press Control A (select all) and you'll see marching ants all round your image. Go to edit>stroke and add a white stroke to your image (make sure white is set as the stroke colour). If it's low resolution a few pixels will be enough. if it's a high res image the size of the stroke may need to be bigger (have a play to see what works).
Also make sure the stroke is set to "inside" so you get nice sharp corners.
Next go to image>canvas size and add a black canvas around your image (say 1" or 2" or whatever size you want the image to be.
this should get you closae but I can explain better when I sit in front of the PC.
All My Gear
5D MkIII & 5D MKII + Grips | 24-70 f2.8L IS | 24-105 f4L IS | 70-200 f2.8L IS MkII | 50 f/1.4 | 85 f1.8 | 100 f2.8 | 1.4x MkII | Tamron 17-35 f2.8-4
relsah
Jul 30, 2007 12:53 |  #8
as for the OP's original question, how do you put the EXIF info?
EOS_JD wrote in post #3635493 (external link)
Radtech1
Everlasting Gobstopper
Joined Jun 2003
Jul 30, 2007 12:59 |  #9
All that is too much trouble.
Go to Image / Canvas Size and increase the size by X pixels (or percent) with a white background.
Then go back to Image / Canvas Size and increase the size by 3X pixels (or percent) with a black background.
Since you have not created a new image, all the exif data is still present.
See how easy. No layers, no strokes, no selecting, no masks and no paying Mike! :lol:
Rad
Be humble, for you are made of the earth. Be noble, for you are made of the stars.
relsah
Jul 30, 2007 13:06 |  #10
do you mean to manually type the EXIF data?
in Mike's script, you don't have to
Radtech1 wrote in post #3637218 (external link)
Rad
EOS_JD
Jul 31, 2007 03:39 |  #11
Rad
Yes that works too.... always more than one way to skin a cat.
All My Gear
EOS_JD
Jul 31, 2007 03:40 |  #12
relsah wrote in post #3637182 (external link)
Not sure how to add the exif info to an image as I've never done that. Would be interested to know too.
All My Gear
5,495 views & 0 likes for this thread, 7 members have posted to it.
2553 guests, 152 members online
