Thread started 29 Jul 2007 (Sunday) 20:41
100-400L Lens Hood
Eagle
Gallery: 62 photos
Jul 29, 2007 20:41 |  #1
Is it just me or does the fit of the lens hood suck? It seems to be to snug going on and off. Especially when I take it on and off backwards for storage in my bag. It seems like it really binds up and have to twist to hard to get it in position. The two other hoods I have on different lenses turn real smooth but not this one. Is everyones the same way? :confused:
7D MKII ■ 10-22 ■ 15-85 ■ 28-135 ■ Σ 50-150 ■ 70-200 f4L ■ 100-400L ■ 580EX II
Gear-PCSmugMug (external link) ShutterStock (external link) Alamy (external link) Eagle's Nest Photography (external link)
GerryL
Jul 29, 2007 20:53 |  #2
My 100-400 seems no different than the fit of my 70-200's (both 4 & 2.8) or any of my other lenses. I had it on and off several times this weekend for soccer on both days and it didn't seem unusual to me.
Denny ­ G
Joined Jul 2004
Jul 29, 2007 21:05 as a reply to  @ GerryL's post |  #3
Just checked mine. Smooth, not a problem reversed or otherwise. It is a Canon ET-83C right?
Denny
MisterJP
Jul 29, 2007 21:14 as a reply to  @ Denny G's post |  #4
I've had problems with mine as well . . . I find that I have to be more careful removing it or it comes mis-aligned on the threads. I think it's because it is massive and the plastic tends to bend a little when you grab it too firmly. Works better when I remove it with even pressure while it's lying on my lap.
______________
www.johnpischke.com (external link)
Canon 5DIII & 5DII • Canon 50 1.4 •
Canon 16-35 2.8L IICanon 24-70 2.8LCanon 100 2.8 Macro • Canon 70-200 2.8L IS • Canon 100-400L • Elinchrom Lights
dr.Zarkoff
Jul 29, 2007 21:26 |  #5
The trick to installing or removing the lens hood on the 100-400L is to twist the lens hood from the base, not from the end of the hood. If you use the end of the hood it distorts the lens hood and causes problems. I hope this helps you as I had problems with the hood at first.
Anke
Jul 29, 2007 21:54 |  #6
dr.Zarkoff wrote in post #3633110 (external link)
Makes sense, that's what I've been doing to mine. Good first post Dr :D
Anke
JWright
Joined Dec 2004
Jul 29, 2007 23:44 as a reply to  @ Anke's post |  #7
Mine has become so worn that it keeps falling off from being bumped. Of course, it's eight years old... I finally put some strips of gaffer's tape on the mating surfaces and that seems to have tightened it up.
John
joeseph
"smells like turd"
Gallery: 264 photos
Joined Jan 2004
Jul 30, 2007 04:36 |  #8
Only time I had trouble with mine is when I muddled up the hood with the one from 24-70. Sheer incompetance as I found niether would fit properly..
TF posting: here :-)
Greg_C
Gallery: 10 photos
Joined Nov 2005
Jul 30, 2007 05:39 |  #9
Eagle wrote in post #3632830 (external link)
Mine used to be like this. I fixed this with a super small application of Silicon lube (pressure pack) applied to a clean rag. I then wiped the ridges on the hood with the cloth. Five second fix, well maybe if you have the lube nearby.
Greg
Blog (external link) | Photogallery (external link) | 1DmkIV + other stuff
Sanity is a madness put to good use.
Pete
Jul 30, 2007 05:47 |  #10
Mine works just fine for me and always has done. I don't do anything special with it. I generally hold it around the circumference (in my palm).
At the zoo, it's on and off all the time.
Pete
UK SE Catch of the Day
Marbeck
Jul 30, 2007 05:54 |  #11
Mine did this and I used a small bit of dishwashing liquid on my fingertip to the mount of the lense then wiped any access off. This worked fine for me. If it drys out just do it again. Did mine about 6 months ago and it's still fine.
Martin Birkbeck :Canon EOS 6D(Gripped):) Canon PowerShot G12:),Canon EOS 1000 film, Canon EF 24-105mm F/4L :cool:Canon EF 17-40mm F/4 L ;) Canon EF 100-400mm F/4.5-5.6 is L,:D Canon EF 70-200mm F/2.8 IS L :D Canon EF 50mm F/1.4 :cool: Canon EF 1.4x II Converter, Kenko Extension Tubes,Canon 430EXII, 430 EX, & 420EX speedlights,Canon ST-E2 speedlite transmitter, Canon ML-3 Macro Ringlight,Tamrac Expedition 8x Bag, www.martinbirkbeckphot​ography.co.uk (external link)
JBaz
Jul 30, 2007 05:56 |  #12
As long as it can rotate around and snap into place, it's fine. Better to be too firm than too loose.
Camera Gear
"Besides the military, photography is the only profession of where you can be proud of shooting people..."
Eagle
Gallery: 62 photos
Jul 30, 2007 16:50 |  #13
Greg_C wrote in post #3635091 (external link)
Marbeck wrote in post #3635127 (external link)
I'll have to try one of these ideas, thanks.
JBaz wrote in post #3635130 (external link)
True, but mine I can't do this ...............
Pete wrote in post #3635109 (external link)
...........cause it takes to much precise gripping and proper twisting.
DDan
Jul 30, 2007 20:21 as a reply to  @ Eagle's post |  #14
Old fly fisherman's trick. Nose grease. When you mount the hood, wipe your index finger down the side of your nose. Then wipe the finger around the mount for the hood. You probably won't notice a difference the first time but after you have done it few times it will work much smoother.
DansRacePhotos.com (external link)
Dangerous Dan
Greg_C
Gallery: 10 photos
Joined Nov 2005
Jul 31, 2007 01:44 |  #15
I hope that is this is the outside of the nose or ewugh!!;):p
Greg
3,000 views & 0 likes for this thread, 15 members have posted to it.
100-400L Lens Hood
867 guests, 134 members online
