Can I use the lens hood that came with the 24-105L ef on the 17-55 ef s? The 24-105 is EW-83H and the one listed for the 17-55 is EW-83J. The EW-83H seems to fit fine on the 17-55.
Is there a difference?
Thanks.
prrs4me Senior Member 326 posts Joined Jul 2007 Location: Long Island, NY More info | Aug 02, 2007 09:21 | #1 Can I use the lens hood that came with the 24-105L ef on the 17-55 ef s? The 24-105 is EW-83H and the one listed for the 17-55 is EW-83J. The EW-83H seems to fit fine on the 17-55.
pagnamenta Senior Member 787 posts Likes: 1 Joined Jan 2007 More info | Aug 02, 2007 10:19 | #2 The lens hood designs are what Canon feels help reduce flare and ghosting, so the hoods specified for the lenses are what you should use. There isn't a negative effect of using the hoods on different lenses. However, you might find that you can see the hood through the viewfinder at the 17mm mark. That's because the 83J hood is wider than the 83H. Canon 1D3, Sigma 70-200 f2.8, Sigma 120-300 f2.8 (sale), 1.4x converter, 580EX.
B3SEO Senior Member 783 posts Joined Jul 2007 Location: Washington State More info | Aug 02, 2007 10:48 | #3 Only one way to find out. Shoot some photos with it, and see if you can the hood. Step back please... I'm armed with a camera...
20droger Cream of the Crop 14,685 posts Likes: 27 Joined Dec 2006 More info | You'll get vignetting of the shorter focal lengths.
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Aug 02, 2007 11:27 | #5 Remember that lens hoods actually are designed for AOV! A 24-105mm on FF camera sees 23 to 84 degree AOV; a 17-55mm EFS lens sees 28 to 77 degree AOV. So at the wide setting, the 24-105 hood is designed to not vignette to 84 degrees, so using it on the 17-55 with the lens wide open would mean that it does not provide as much shading as the 17-55 hood. 20droger wrote in post #3655851 You'll get vignetting of the shorter focal lengths. Hoods are designed for the widest end of the FL range, not the narrowest! You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
pwm2 "Sorry for being a noob" 8,626 posts Likes: 3 Joined May 2007 Location: Sweden More info | Aug 02, 2007 13:41 | #6 Wilt wrote in post #3655990 Remember that lens hoods actually are designed for AOV! A 24-105mm on FF camera sees 23 to 84 degree AOV; a 17-55mm EFS lens sees 28 to 77 degree AOV. So at the wide setting, the 24-105 hood is designed to not vignette to 84 degrees, so using it on the 17-55 with the lens wide open would mean that it does not provide as much shading as the 17-55 hood. Hoods are designed for the widest end of the FL range, not the narrowest! But the shortest focal lengths are the widest 5DMk2 + BG-E6 | 40D + BG-E2N | 350D + BG-E3 + RC-1 | Elan 7E | Minolta Dimage 7U | (Gear thread)
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Aug 02, 2007 13:57 | #7 Situation A (17-55): 17mm sees 77 degrees on APS-C You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
pwm2 "Sorry for being a noob" 8,626 posts Likes: 3 Joined May 2007 Location: Sweden More info | Aug 02, 2007 14:04 | #8 Wilt wrote in post #3656884 Situation A (17-55): 17mm sees 77 degrees on APS-C Situation B (24-70): 24mm sees 84 degrees on FF So if you took Hood B and put it on lens A, at 17mm (77 degrees) it would not vignette because the hood is designed for a wider 84 degree AOV; but it also would not provide as good quality of shading from strong light sources like the sun. And if you took Hood A and put it on lens B (which is not what the OP was asking), at 24mm it would vignette because the lens sees 84 degrees yet the opening of the hood is designed for the narrower 17mm (77 degree) AOV At the other end of the focal range, which is what 20droger was commenting about... So if you took Hood B and put it on lens A, at 55mm it would not vignette because it is designed for a wide 24mm AOV; and it also would not provide as good quality of shading from strong light sources like the sun, as a hood for a dedicated tele zoom or single FL zoom! And if you took Hood A and put it on lens B, at 70mm it would not vignette because it is designed for a wide 17mm AOV; and it also would not provide as good quality of shading from strong light sources like the sun, as a hood for a dedicated tele zoom or single FL zoom! No, 20droger did write: You'll get vignetting of the shorter focal lengths. I.e. that the wrong hood will give vignetting at the wide end of the lens. You are talking about the same thing. No one in this thread is worrying about the 55mm/70mm range. 5DMk2 + BG-E6 | 40D + BG-E2N | 350D + BG-E3 + RC-1 | Elan 7E | Minolta Dimage 7U | (Gear thread)
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Aug 02, 2007 14:06 | #9 pwm2 wrote in post #3656937 No, 20droger did write: I.e. that the wrong hood will give vignetting at the wide end of the lens. You are talking about the same thing. No one in this thread is worrying about the 55mm/70mm range.
pwm2 "Sorry for being a noob" 8,626 posts Likes: 3 Joined May 2007 Location: Sweden More info | Aug 02, 2007 14:07 | #10 Happens to us all 5DMk2 + BG-E6 | 40D + BG-E2N | 350D + BG-E3 + RC-1 | Elan 7E | Minolta Dimage 7U | (Gear thread)
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Aug 02, 2007 14:09 | #11 When I cannot recall what the original question is, and provide an answer to a completely different question, then I know I am suffering from Old Timer's Disease and should disconnect my internet cable permanently! You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
pwm2 "Sorry for being a noob" 8,626 posts Likes: 3 Joined May 2007 Location: Sweden More info | Aug 02, 2007 14:22 | #12 Ah, but a large part of our reading skills are based on our assumptions - what we expect to read. When we have made a decision what a sentence says, we can read it many times without seeing the error - or that the sentence may have several meanings. While missfiring sometimes, that extrapolation skill is probably one of the most important aspects of humanity. 5DMk2 + BG-E6 | 40D + BG-E2N | 350D + BG-E3 + RC-1 | Elan 7E | Minolta Dimage 7U | (Gear thread)
gasrocks Cream of the Crop 13,432 posts Likes: 2 Joined Mar 2005 Location: Portage, Wisconsin USA More info | Aug 02, 2007 14:22 | #13 I have an 83H hood and an 83 hood (made in China, bought from eBay.) Use them interchangeably on either the 10-22, 17-55 or 24-105. No problem. GEAR LIST
20droger Cream of the Crop 14,685 posts Likes: 27 Joined Dec 2006 More info | Allow me to correct myself.
Thanks for all the input.
| Latest registered member is semonsters 925 guests, 116 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
