Thread started 27 Jun 2002 (Thursday) 12:46
Poster sized / lower res???
mlfrancis
Joined Dec 2001
Jun 27, 2002 12:46 |  #1
I've been getting pictures up to 8x10 "developed" at Sam's club and have been very happy with them.
I was looking on their site and they now offer poster size prints up to 36x48. These aren't cheap so I don't plan on getting any, but I noticed they said something that didn't make sense to me. Maybe someone here could explain.
Their site says that poster prints require less resolution in the picture to produce the poster. They say a picture that can produce a 16x20 or larger poster might not have the resolution to print a 8x10 or smaller photo.
Certainly these are different printing processes, but I just found it really weird. Has anyone tried to get any of these, or similar, posters made? Any good results?
Later,
Michael
dcsmith40D
Mar 28, 2008 16:52 |  #2
It is taking a long time to get an answer. I'd be interested in the answer myself.
Canon 40D; 50 f1.8, 70-200 f2.8 IS L, 580 EX II, 1.4 TC, 24-70 f2.8 L, (2) 430 EX II
David
Cody21
Mar 28, 2008 17:08 |  #3
From what I've read, it's all about the number of megapixels that the picture was shot with. You really only need a camera that will shoot at a minimum of 4 Mp to generate an 8x10" photo. For a 16x20", you need a minimum of 8Mp, and for a 24x36" you need a 10-12 Mp camera.
So I don't know what they mean by "resolution" in that term. Sounds kind of backwards the way you stated. I mean if a "perfect" 16x20 pic is created, makes no sense that you can't also make smaller pictures of it. It almost sounds like their talking about "image ratio" ... hmmm...
5DM3 | 16-35mm f/2.8L II USM | 70-200mm IS f/4L | 24-105 f/4L | Sigma 18-50mm f2.8 | Speedlite 430EX
Stocky
Mar 28, 2008 23:26 |  #4
The difference is that you expect to view an 8x10 at arms length or closer while you would typically look at a poster from a little farther away. Normally you probably want your prints at around 300 DPI, but I think you can get away with 150 or even 100 DPI for the posters.
The easy answer is to get a comparatively cheap 8x10 printed as a cropped portion of the image you want to make the poster to see how it would look. If its good enough for you then get them to print the big version.
Always happy to hear some critique
gear list
macropod
Mar 28, 2008 23:42 |  #5
In normal photography terms, a 48*32in poster would typically be viewed from about 24in away, where as a 10.67*8in print (same aspect ratio) would typically be viewed from about 16in away. Thus the smaller print needs to be printed at a 50% higher dpi than the larger print. Conversely, the larger print would require 3 times as many pixels in each direction for the same definition at those distances.
When your printer talks of posters, I suspect he/she isn't talking about photographic quality prints, but a much lower 'poster' quality. People are usually much more tolerant of low resolution in something they regard as a poster (eg for a shop display) than a work of art to be viewed in a gallery on on the loungeroom wall. For posters, you might even be able to get away with fewer pixels than for the smaller 'photo quality' print.
Cheers
SkipD
Joined Dec 2002
Mar 29, 2008 05:01 |  #6
mlfrancis wrote in post #14806 (external link)
The correct term is usually considered to be "printed" rather than "developed" for just making prints.
Exposed film must be developed before it becomes either a negative or a slide (depending on the film type).
Skip Douglas
2,545 views & 0 likes for this thread, 6 members have posted to it.
1742 guests, 146 members online
