Thread started 08 Aug 2007 (Wednesday) 18:59
Cactus v2 and 430EX
twofer
Aug 08, 2007 18:59 |  #1
I can't get it to fire. When I press the test button the receiver lights up so the channel is good. The 430EX is set to manual mode. Am I missing something here?
FlashZebra
This space available
Aug 08, 2007 23:22 |  #2
Where are all the V2 zealots now, when they are needed?
Enjoy! Lon
pepperoni
Aug 08, 2007 23:34 |  #3
#1 problem is the thin plastic coating is still on the battery in the receiver.
Mamiya. Canon. Elinchrom.
farrukh
Aug 08, 2007 23:40 |  #4
First of all check if the flash is properly seated on the receiver's shoe and then try. if problem persists then check the receiver's battery as the one provided by Cactus in the box is only for testing and mostly they come dead. You need to buy new CR2 batteries and then try.
The third thing to check is that if you actually got V2 trigger or V1. as Canon flashes don't work with the V1.
I have v2 and it triggers my 430ex flawlessly.
5D Mark II + 40D | Lenses: Sigma 150-500mm BigmOS / Canon 24-105mm F4L IS / Canon 70-200 F4L IS / Canon 85mm 1.8 / Sigma Macro 70mm f/2.8 EX / Sigma 10-20mm EX / Canon 50mm f/1.8 II / Sigma 1.4x APO TC / Kenko 2x PRO300 DG. Lighting: Canon 580EX II + Metz 58 AF-1 + Sunpak 383...
farrukh
Aug 08, 2007 23:41 |  #5
pepperoni wrote in post #3694748 (external link)
He is getting red light so thats not the case.
twofer
Aug 09, 2007 08:33 as a reply to  @ farrukh's post |  #6
FlashZebra wrote in post #3694681 (external link)
Enjoy! Lon
Someone's a little cynical...
farrukh wrote in post #3694767 (external link)
I will give that a whirl tonight. Thanks!
FlashZebra
Aug 09, 2007 12:10 |  #7
twofer wrote in post #3696316 (external link)
You may want to read this thread also:
https://photography-on-the.net/forum/showthre​ad.php?t=360306
Enjoy! Lon
twofer
Aug 09, 2007 15:07 |  #8
FlashZebra wrote in post #3697362 (external link)
Enjoy! Lon
Meh. I'll drop a fresh battery in the receiver tonight and if doesn't dance then I'll send it back for a refund. No biggie.
nicklk
Aug 09, 2007 15:20 |  #9
The batteries are typically dead by the time the user gets them, replace em and you are good
Canon EOS 70D, EOS 40D | EF 50mm f/1.8, EF 28-135 f/3.5-5.6 IS USM, EF 70-200mm f/4L | Sigma 18-35mm f/1.8 DC HSM Art | DJi Phantom 3 Professional | GoPro 360 Rig
twofer
Aug 09, 2007 18:22 as a reply to  @ nicklk's post |  #10
Well I found out that it wasn't the battery. The shoe itself isn't holding the flash tight enough and it doesn't make the connection. I can press down on the flash and it goes every time.
bieber
Aug 10, 2007 00:07 |  #11
Well, two options. Send it back, or bust out a pair of pliers. I took the latter option with a video card once, and it still works to this day, although it probably wasn't the best course of action ;)
EOS 20D w/ BG-E2 grip
Nifty fifty, EF 28mm f/2.8, EF 70-200mm f/4L USM
Speedlights SB-25/SB-26/580EX, Pocket Wizards and such
My Gallery (external link)
twofer
Aug 10, 2007 06:04 |  #12
bieber wrote in post #3700876 (external link)
Heh, well you're talking to a country boy so I think you can guess which course of action I took. Working great too. :)
Headcase650
Joined Jun 2004
Aug 10, 2007 15:41 |  #13
I purchased a PC to hot shoe adapter, as I didn't want the V-2 receiver supporting my flash on a stand. Its a metal shoe with an 8 inch PC cord coming out the side with a 1/4-20 hole in the bottom. I mounted the shoe to the stand with the flash on it and plug the PC cord into the receiver that I velcroed to the stand. It looks nice and keeps the flash head at about the right level for my umbrellas and has worked perfectly.
60D, Canon 18-135 IS, Sigma 10-20 hsm, 24-70 2.8 hsm, 70-200 2.8 hsm, 430EX II, and all the other stuff that goes along with it.
3,047 views & 0 likes for this thread, 7 members have posted to it.
Cactus v2 and 430EX
1732 guests, 167 members online
