Thread started 11 Aug 2007 (Saturday) 11:57
Macro setup questions.
Chako
Joined Jul 2004
Aug 11, 2007 11:57 |  #1
First off, apologies if this is in the wrong section. I wasn't clear on where to post this.
Prior to my getting the Tamron 90mm Macro (just yesterday), I was using my old trusty Canon 100-300mm lens with a set of Kenko auto extension tubes for taking close ups of flowers and bugs.
For lighting, I was using an old vivitar flash bracket with a small micro ball head along with the off cord cable and softbox. The problem is this, the micro ball head is too loose in the vivitar flash bracket (hot shoe style and not screw on, even though the micro ball head has the threads). I just know one of these days, I will tilt the camera backwards, forget to place my thumb as a stopper, and watch my 580EX flash go for an expensive dive.
Here is an image of my current set up.
I am trying to improve my macro photography, but also try and get the flash more securely held.
Here are the questions that I would love to have help on.
1. What would you recommend for a better macro flash bracket? The local photo store has a strobofram quickflip flash bracket that wedding photographers like to use. I noted that the flash shoe has a tightening knob on the flash bracket. Too bad my current Vivitar flash bracket didn't have something to prevent the ball head from sliding out so easily (I have tried paper shims etc.). I was also looking at possibly the Manfrotto macro flash bracket. Any comments on its uses etc?
2. My eyesight isn't the best, and I am thinking about getting a right angle viewfinder adapter for my 20D. I have read up on the Canon angle finder C, also saw that Hoodman has one, and even a product called Seagull. Which one would you recommend? I would be using its magnification to better get the manual focus down path.
Anyways, here is what I am currently getting with the Tamron and flash setup (photos taken early this morning...before sunrise). Apologies for the focusing I guess...reason why I am looking into getting the angle finder. I haven’t tried the macro with the extension tubes yet.
C&C always welcome.
Chako's Gear: https://photography-on-the.net …p?p=3583080&pos​tcount=720
Mrvile
Aug 11, 2007 11:59 |  #2
Have you looked through the "Show us your macro rig" thread yet? The Delta flash bracket seems to be quite popular and works quite well.
Eric
Canon EF 70-300mm f/4-5.6 IS USM Review
angryhampster
"Got a thick monopod?"
Aug 11, 2007 12:38 |  #3
Mrvile wrote in post #3708654 (external link)
I love mine. It's perfect for macro work.
Steve Lexa
Iowa City Wedding Photography (external link)
Chako
Joined Jul 2004
Aug 11, 2007 13:08 as a reply to  @ angryhampster's post |  #4
No. I was not aware of the thread. Going to look it up quickly.
Chako
Joined Jul 2004
Aug 11, 2007 13:36 as a reply to  @ Chako's post |  #5
Not sure if the Delta bracket would do the trick.
Is the articulated section strong enough to hold a 580EX flash and softbox in place and steady?
What I like about my current setup is that the flash does not move once it is locked in place. I only have the major problem of the whole thing sliding out backwards off the Vivitar bracket if I move the camera in an upwards plane.
But thanks to the pointing of that thread, it was quite informative.
angryhampster
Aug 11, 2007 14:37 |  #6
Chako wrote in post #3709077 (external link)
I don't use a softbox, but my sigma ef-500 (very close to 580 in size and weight) and big flip it barely jiggle when I'm shooting handheld.
Steve Lexa
scot079
Aug 11, 2007 14:40 |  #7
alot of people with the delta use a home made diffuser or a sto-fen. my delta is on the way...can't wait for it!
- Tim
www.timadkinsphoto.com (external link)
GEARandFEEDBACK
Chako
Joined Jul 2004
Aug 11, 2007 15:14 |  #8
Ok that settles it then. I will see if the local camera shop can get me one. It does look like it would solve my problem.
I am still fooling around with the Tameron 90 Macro. I was lucky enough to find a Tamron 2X BBAR teleconverter for Canon mount at a local pawn shop. Paid 28 dollars for it. Here is what I got with the 90 macro and teleconverter. All photos were hand held and in a slightly windy condition. I am still having great difficulty in getting the focus just right. More practice, and possibly an angle finder might help along the way.
I thought they were all trash..but somehow, I sort of like the details each photo show.
scot079
Aug 11, 2007 15:16 |  #9
good shots.
I just shot some flies this evening. to lose the shallow DOF, i used LordV's CombineZM focus stacking method. Works great, just have to use a tripod. FREE SOFTWARE
- Tim
GEARandFEEDBACK
Chako
Joined Jul 2004
Aug 11, 2007 16:24 |  #10
How can you stack images of a moving subject? Now you have my curiosity picked. I had assumed that to focus stack images, they should be of static objects, much like doing HDR photos.
scot079
Aug 11, 2007 16:28 |  #11
correct just like HDR. i used a "slightly unconscious" fly.
- Tim
GEARandFEEDBACK
amfoto1
Aug 11, 2007 17:27 |  #12
Hi,
Is the Stroboframe Lepp Macro Flash Bracket still available? I use one with MT-24EX. The bracket provided with the MT-24EX didn't provide enough flexibility for my tastes. If you want small ballheads under the flash units, the Deluxe version of the Lepp bracket came with those.
IMHO, 580EX is way too strong a flash for macro work (well, actually I don't have a 580EX, but use three 550EX... close enuf in terms of light output and still not my usual choice for macro). A 220EX might be a better flash, if using a non-macro-dedicated flash.
A cheap and easy flash diffuser is a couple layers of white gauze held over the flash tube with a rubber band. White gauze is available at just about any grocery store or pharmacy. Add or subtract layers to increase or decrease diffusion effect.
A small reflector is also handy. I use one from Photoflex that's got a choice of five sides: gold, silver, silver/gold mixed, white diffusion and black. It's not only useful to bounce some light (daylight or flash) for fill, but also can provide some handy "portable shade" for high contrast, full sun, noontime shooting. Folds up small enough to fit in one of my backpack's pockets.
silvex
Gallery: 21 photos
Aug 12, 2007 00:39 |  #13
Nice shots, but maybe using F9-F11 will improve the DOF.
-Ed
CPS Platinum Member.
Canon Gear
SilvexPhoto.comexternal link
Lester ­ Wareham
Moderator
Gallery: 3035 photos
Best ofs: 5
Aug 12, 2007 03:45 |  #14
Yes, check the macro section, those that use standard flashed with a bracket talk about it there, myself I use the MT-24EX twin macro flash. It will be worth you getting a ETTL-II compatible flash IMHO, the MT-24EX works very well and I don't need to figure magnification light loss into the flash setting.
You might find a bulky reflector like that too big for getting into small insects very close BTW.
Focus stacking on moving subjects can be done, LordV has a tutorial on using combineZ in the macro section (all these threads should be stickies near the start). I tend to manually stack using layers in photoshop. A good technique can be to use the "motor drive' mode and fire off shots as you sweep the focus through the subject, just try to avoid any rotation.
Macrophotography by LordV
scot079
Aug 12, 2007 03:49 |  #15
interesting stuff, i just went out and tried some of LordV's dewdrop refractions. There was a tiny bit of wind, so the stacking didn't look that good. I used CombineZM. I'll try the manual method in PS. Thanks! Here's one...not stacked so the DOF is SHALLOW!
- Tim
GEARandFEEDBACK
4,816 views & 0 likes for this thread, 9 members have posted to it.
1307 guests, 176 members online
