can anyone explane how can i, and or can i at all underexpose backgrowng in light room? here is one picture, now how should i take this shhot to get backrown dark (even almost black) but person, as it is? thank you a lot!!!
Cherepashka Member 74 posts Joined May 2007 Location: London More info | Aug 11, 2007 14:01 | #1 can anyone explane how can i, and or can i at all underexpose backgrowng in light room? here is one picture, now how should i take this shhot to get backrown dark (even almost black) but person, as it is? thank you a lot!!!
iLuveKetchup Senior Member 455 posts Joined Mar 2006 Location: NYC More info | Aug 11, 2007 14:09 | #2 What's your setup? The quick answer is to stop down your aperture.
oh,set ups... i am so new in lighting... have two elinchrome strobes and just playing arownd with them, but never get right (with underexposing backgrownd) !
Franko515 "doped up on pills" 2,478 posts Joined May 2006 Location: Crete, Illinois More info | I believe if you put more distance between the subject and background then move the light closer to the subject the background will go dark or black if you like. Light, composition, shooting technique matter to the end quality most. -Pekka
MrScott Member 243 posts Likes: 2 Joined Apr 2006 More info | Aug 11, 2007 16:11 | #5 Well in that 2nd pick you outed the sun in the window behind the subject. Turn the lights down or look into some other light modifiers that control and direct the light rather than spreading all over the room.
thank you, guys, a lot!!!
FlashZebra This space available 4,427 posts Joined Mar 2006 Location: Northern Kentucky More info | Aug 12, 2007 09:14 | #7 Radically increase the distance from your subject to your background, while maintaining the subject to camera distance.
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Aug 12, 2007 09:54 | #8 The flash to background distance is key, as others have stated. However, key information has been omitted: You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
TMRDesign Cream of the Crop 23,883 posts Likes: 12 Joined Feb 2006 Location: Huntington Station, NY More info | The suggestions offered are all good ones but for the particular shot you've posted it appears to be in a home and there is furniture that I imagine you're not going to be moving around for the shoot. In that case you really don't have the option of moving the subject further from the background and you're most likely going to have to move your lights closer to the subject and positioning them so you have as little spill in to your background area as possible. This will create greater separation between subject and background and will allow for proper exposure of the subject while causing the background to go darker. Robert
| Latest registered member is zachary24 1441 guests, 135 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
