Thread started 13 Aug 2007 (Monday) 22:46
Sigma 12-24 - Can you use polarizer?
RichNY
Aug 13, 2007 22:46 |  #1
I'm looking at using a 12-24 on a 1.3x lens to get some wide angle for landscapes. It appears that you can't use a polarizing filter on this lens- is this correct?
It just seems hard to believe that there is no polarizing option on a lens whose focal length make it one of the lenses that you'd most want to use a polarizer for.
I searched the forum and didn't read about anyone commenting on this so what am I missing?
This is the only lens that can go ultra wide on a 1.3x w/o cutting up a 10-22, right? I'm used to the 10-22 on a 30D and don't want to be stuck with a 16-35 on the IIN loosing all that width.
Nikon D3, D300, 10.5 Fisheye, 35 f/1.4, 50 f/1.4, 85 f/1.4, Zeiss 100 f/2, 105 f/2.5, 200 f/4 Micro, 200 f/2, 300 f/2.8, 14-24, 24-70, 70-200, SB-800x4, SB-900, SU-800, (3) Sunpak 120J (2) Profoto Acute 2400s,Chimera softboxes, (4)PW Multimax, (6) C-stands, (3) Bogen Superbooms, Autopoles
Raphael ­ Emond
Aug 14, 2007 01:46 |  #2
No you can't...
You can use one (82mm) with the included front support but it will vignette like crazy..
So it's application is rather small...
Maybe check the Sigma 15-30? or Canon 14/1.4L
Canon Rebel XT, BG-E3, Sigma 12-24 EX DG HSM, 28/2.8, 50/1.8, 24-105L IS USM, Sigma 70-200 2.8 EX DG HSM
420EX, Sigma 1.4X Converter, Moded Off-Shoe Cord 2, 2x1Gb + 1x2Gb, Pelican 1550 Case, Hoya IR72, Mono-Tripod.
cdifoto
Don't get pissy with me
Aug 14, 2007 01:54 |  #3
Sigma 12mm on 1.3x w/filter cap, no filter:
Raphael Emond wrote in post #3723925 (external link)
The 14mm L is f/2.8
Nick_C
Aug 14, 2007 02:48 |  #4
You need a good tidy up there mate ;-)a
cdifoto
Aug 14, 2007 02:48 |  #5
Nick_C wrote in post #3724049 (external link)
Everything has its spot. Where you see it is where it goes. :p
Nick_C
Aug 14, 2007 02:53 |  #6
cdifoto wrote in post #3724050 (external link)
Where it lands it stays aye! lol ;)
cdifoto
Aug 14, 2007 03:00 |  #7
Nick_C wrote in post #3724064 (external link)
Roger that.
foxbat
Joined Jan 2005
Aug 14, 2007 03:23 |  #8
cdi is right. I have the 12-24 and it does exactly what he says on the 1Dmk2 with the cap sleeve in place. The only workaround I can think of would be to hold up a polariser made for drop-in systems in front of the lens. I've done this with GND's and while it's not ideal and you look a bit silly it does work.
Andy Brown; South-east England. Canon, Sigma, Leica, Zeiss all on Canon DSLRs. My hacking blog (external link).
Nick_C
Aug 14, 2007 03:26 |  #9
I was thinking about this lens on the 5D, I could rule out using any filter then with this one.
Lani ­ Kai
"blissfully unaware"
Aug 14, 2007 03:50 |  #10
No you can't...
14mm f/1.4L!!!
On a more serious note, neither the Sigma 15-30 nor the Canon 14mm f/2.8L take front filters. Your choices for using a filter on wide angle lenses for APS-H are:
1. Canon 16-35mm f/2.8L
2. Sigma 10-20mm past a certain focal length
3. DIY-project for adapting Cokin Z-Pro filters to the Sigma 12-24 (I've seen it done...)
Website (external link) | Facebook (external link) | Equipment list
RichNY
Aug 14, 2007 06:57 |  #11
cdifoto wrote in post #3723941 (external link)
The 14mm L is f/2.8
Don- I'm confused as to why you are getting that look compared to the way it looks in the lens archive (ignore first pic on 10D and scroll for the lens an 1.3x and FF cameras)
https://photography-on-the.net/forum/showthre​ad.php?t=298928
I've been under the impression for a long time that this is the best ultrawide for a 1.3x camera unless you want to settle for 16mm as your starting focal lenght. Is there a better solution?
foxbat
Joined Jan 2005
Aug 14, 2007 07:00 |  #12
Rich, the 12-24 comes with a slide-on sleeve that covers the petal holder and is what you clip the lens cap into. The front of this sleeve is threaded for filters and that pic shows what it looks like on a 1.3x when the sleeve is attached. If you remove this sleeve for normal shooting then there is no vignetting from the remaining fixed petal hood.
[edit] You can see the sleeve on and off in the photozone review (external link).
Dellboy
Aug 14, 2007 07:29 |  #13
I used to think that it was odd that the 12-24 could not be used with filters but it was pointed out to me ( probably by someone on this forum ) that when a polarizer is used at these FLs ( especially on full frame )the sky darkens unevenly and a graduated dark to light blue look is all that's achieved - often quite undesirable. Should I ever pick up a UWA then I think I'll stick a with photoshop correction.
Before changing your lense or bodging a lense decide weather this is something you'd be happy to live with, although on a 1.3X the effect won't be as pronounced as with a full frame.
incidentally the tamron 12-24 I believe can be used on a 1.3X with only a small amount of vignetting wide open at FLs below about 15mm and it takes filters. This may be the way to go.
oh and it's F4 too and stopped down a bit vignetting shouldn't be a problem
cdifoto
Aug 14, 2007 07:30 |  #14
I usually just crank up the blue channel in Lightroom to the point of making the sky awesome but not throwing anything in the ground out of whack.
SkipD
Joined Dec 2002
Aug 14, 2007 19:47 |  #15
RichNY wrote in post #3723278 (external link)
You probably would not want to use a polarizing filter on an ultra-wide lens even if it could be mounted properly. Why? With a wide-angle lens, you take in the sky across such a wide viewing angle that the amount of darkening of the sky (by the polarizing filter) changes radically across the image. This is because the amount of polarization of the sun's light varies with the angle to the sun.
Skip Douglas
3,731 views & 0 likes for this thread, 14 members have posted to it.
1346 guests, 136 members online
