drisley wrote:
So, when you buy a monopod, you then buy the ballhead seperately?
I see by your gear that you have the 70-200 f4. If you have the tripod collar then you won't need a ball head when you use this lens on a monopod. The whole thing actually works better WITHOUT a head in this case. You can quickly rotate the lens/camera with the tripod collar and the weight of the setup stays directly over the centre of the monopod.
If you do have a ball head then you'd pretty much have to lock it down, otherwise you introduce an extra pivot point, kind of like having a trick knee, and then the whole thing would be unstable when you losen things to adjust your vertical/horizontal composition.
I use the monopod only on heavy lenses with tripod collars (70-200 f2.8 & 300 f2.8 ) where I'm trying to shoot action and I need at least some freedon of movement. If I'm working with shorter lenses and still trying to shoot action I'll just handhold the camera. If it's a shorter lens and I want the best results I can get, then I use a tripod. With my workflow a ball head (or any kind of head for that matter) isn't needed on my monopod.
"There's never time to do it right. But there's always time to do it over."
Canon 5D, 50D; 16-35 f2.8L, 24-105 f4L IS, 50 f1.4, 100 f2.8 Macro, 70-200 f2.8L, 300mm f2.8L IS.
