Thread started 17 Aug 2007 (Friday) 12:43
Switched to Mac
tipsy
*hic
Aug 17, 2007 12:43 |  #1
Finally switched to Mac today and bought a 13 inch Macbook, 80GB, 1GB RAM, etc etc. The cheapest model.
Ive been playing around and refreshing my memory of mac, and just wanted to ask a few things. Is it worth getting an antivirus for my MacBook? Or should i just trust apple saying macs dont get viruses. And if i should, does anyone know of any free ones like AVG for PC's?
Also,
I just plugged in my 20D to see how it performed on my mac. And Lo, it doesnt show that its connected?!?! Do Mac's need drivers for a 20D?
Appreciate the help guys!
x
www.racmedia.co.uk (external link)
TV Cameraman and Photographer
EOS 5D + 24-70mm f2.8 are my main weapons of choice.
Village_Idiot
GREATEST POTN MEMBER EVER
Aug 17, 2007 12:46 |  #2
I suggest a card reader anyways. Moves the file much quicker than a direct cable to the camera and they can be picked up cheap.
I don't run. AV stuff. It's not needed for the most part. It's mainly insured to catch viruses that you would pass on to a Windows machine if you had files with viruses in them.
My village called. I was told that they missed me.
Speedotron users, untie!
tipsy
*hic
Aug 17, 2007 12:49 |  #3
I intend to get a card reader, last one broke. However in the mean time, why isnt it showing up that my camera is connected?
x
Zilly
Aug 17, 2007 12:55 |  #4
i dont know why your camera isnt showing up as mac does occasonaly use drivers
talk us threw what ya do
Dom
Follow my adventures on twitter (external link)
Car Photography (external link)
Village_Idiot
Aug 17, 2007 12:56 |  #5
tipsy wrote in post #3744755 (external link)
x
Drivers then probably. Do you have the CD that came with the camera? Best suggestion until some one that knows what is going on chimes in is to check that out or check out Canon's website.
Sorry, I'm not much help. I just strictly use a card reader.
tipsy
*hic
Aug 17, 2007 12:59 |  #6
i do exactly the same as i would on pc. connect the camera via usb, switch on, ptp communication.
ive tried normal communication too and that doesnt work either.
x
Zilly
Aug 17, 2007 13:00 |  #7
go > aplications > image capture
how ever im now getting into the relms of unknown as i work in aperture
Dom
Village_Idiot
Aug 17, 2007 13:04 |  #8
Zilly wrote in post #3744787 (external link)
i dont know why your camera isnt showing up as mac dosnt use drivers
That's totally untrue. OS X uses drivers and some times requires installs. I've ran acrossed it before with a MOTU analog to digital interface used for recording music. MOTU, the company, mainly focuses on OS X and Macs, but I still had to install drivers. OS X wouldn't even recognize the device when it was plugged in and powered. Installed the drivers and then it worked fine.
Zilly
Aug 17, 2007 13:06 |  #9
woops apologies post has been edited
Dom
Village_Idiot
Aug 17, 2007 13:10 as a reply to  @ Village_Idiot's post |  #10
Issue: Is my camera/software compatible with Mac OS 10.4 Tiger?
Solution: Mac OS 10.4 Tiger Compatibility Information
While conducting compatibility tests between the recently released Mac OS X Tiger (10.4) and the software that is bundled with our image communication products, we have confirmed the occurrence of the following problems.
For full compatibility with Mac OS X Tiger (10.4) the following applications have been certified:
ImageBrowser ver. 5.5 and higher(OS 10.2-10.4)
Digital Photo Professional ver. 2.0.3 and higher(OS 10.2-10.4)
These versions are available as updates for each supported Canon digital camera model and are accessible from the respective camera models download pages.
PowerShot cameras supporting the PTP standard appear to be fully compatible.
Please go here (external link) to select your camera models download library.
This is a quick summary of the problems with earlier versions for your information.
Problems applicable to EOS DIGITAL
Problems applicable to Compact Digital Cameras / Digital Video Cameras / EOS Digital Cameras / CP Printers
1.Forced shut down during the installation of ImageBrowser 5.1/5.2.0/5.2.0a
Forced shut down may occur when one of the versions of ImageBrowser listed above is installed under the following conditions.
  • When updating from 5.1 to 5.2.x (Whether installing from the Solution Disk or from the Updater is irrelevant)
  • When re-installing 5.1/5.2.x after they are installed once and ImageBrowser is subsequently uninstalled
  • When installing with the OS in an English-language environment
Workaround:
Investigation is still underway to find an effective workaround.
In some cases, the program can be installed normally by deleting the following files:
  • English: /Library/Preferences/c​om.canon.ImageBrowse.C​olorManagement.plist
2. ImageBrowser 5.1.1/5.2.0 function unusable
The following function of ImageBrowser is confirmed to be unusable:
  • Unlocking images: Images can be locked but locked images cannot be unlocked
Workaround:
Locked images can be unlocked by opening them with the Finder and deselecting "Locked" under "Get Info" in "General".
3. Alias display problem
There are cases where the aliases of applications may not be displayed normally.
Workaround:
Aliases can be displayed normally by restarting the OS.
4. Problems in setting the number of pages to print
It was confirmed that when setting the number of the pages to print with the applications that have printing functions, the number may stay at the default number and cannot be changed.
Workaround:
It was found, however, that the problem might be solved in some cases with the following method:
  • By moving the location of the window for setting printing options.
  • By setting the number of pages to print immediately after the application is started.
1. Some models cannot be connected to the software
Two models, namely EOS 20D and EOS Kiss Digital N/EOS DIGITAL REBEL XT/EOS DIGITAL 350D, cannnot be connected to the following software:
  • EOS Viewer Utility: cannot be connected to EOS 20D
  • ImageBrowser 5.1.1/5.2.0 (CameraWindow): cannot be connected to both EOS 20D and EOS Kiss Digital N/EOS DIGITAL REBEL XT/EOS DIGITAL 350D
Workaround:
There is no effective workaround.
2. Digital Photo Professional 1.5/1.6.1 functions unusable
The following functions of the Digital Photo Professional cannot be used:
  • Stamp Tool function: The effect of using this tool is not shown in display.
Workaround:
  • "Batch Process" in Image Transfer settings: Changes made to the destination application settings are not reflected in the actual settings.
    (If an application is specified in the "Open image using software" setting, that application does not start. The application set before the change, however, does start.)
Workaround:
The setting can be changed by the following procedure.
  1. Specify the desired application for the image transfer.
  2. Start batch processing.
  3. If the application set before you changed the setting starts, close it.
  4. Restart Digital Photo Professional.
The countermeasures for these problems are now being discussed.
Mac OS X's Image Capture Application
Mac OS X 10.1 and newer come with Image Capture drivers that support most of Canon's digital cameras with USB interfaces. When a compatible camera is connected to a compatible Mac computer running OS X 10.1 and newer, the computer detects the camera and automatically launches Image Capture. This Apple program allows JPEG images in the camera to be downloaded to the Macintosh. NOTE: RAW files from Canon digital cameras cannot be downloaded in OS X via Image Capture. We suggest the use of File Viewer Utility or an external card reader. Also, movie files shot with PowerShot cameras cannot be downloaded in OS X via Image Capture or iPhoto. We suggest the use of ImageBrowser or an external card reader.
Additionally, Image Capture can access JPEG images directly from a CompactFlash card using an OS X-compatible card reader or using a PC Card Adapter in the PC Card slot of an Apple PowerBook.
For the latest list of Canon Digital Camera products that are compatible with Mac OS X please visit:
http://www.apple.com/m​acosx/upgrade/devices.​html (external link)
Village_Idiot
Aug 17, 2007 13:14 |  #11
Post from Fred Miranda that might work...
Hi Michael:
I just happened to have my XT and MBP sitting here on the dining room table, so I gave it a try. Works great for me. My OS X is version 10.4.9 and my EOS utility version is 2.0.1.
Is your Mac just not recognizing the camera, do you have all the Canon updates installed, sure the USB cable connection is OK, etc.?
Regards,
Dean
tipsy
*hic
Aug 17, 2007 13:22 |  #12
I dont use any of the eos utilities
i dont use them.
I just used to drag and drop to a folder on windows and process with capture one pro and photoshop from there on in. So no, i dont have ANY of the EOS utilities installed, do i need them?
I just shut down my macbook and its charging, im giving it the 2 full cycles of a new laptop. I'll try installing the driver off the website when it wakes back up and ill see what happens then.
Thanks for the help village_idiot!
x
breal101
Aug 17, 2007 13:27 |  #13
Try opening EOS utilities, you should be able to download from there.
"Try to go out empty and let your images fill you up." Jay Maisel
tipsy
*hic
Aug 17, 2007 13:27 |  #14
Maybe i should just give in and install EOS utilities
there is no drivier.
x
Village_Idiot
Aug 17, 2007 13:29 |  #15
breal101 wrote in post #3744990 (external link)
tipsy wrote in post #3744954 (external link)
i dont use them.
x
Apparently OS X requires EOS utilities to transfer files from the camera to the computer. That's why using a card reader is a little easier. When you get one and hook it up, it's just a matter of opening a file folder and dragging and dropping the contents to where you want it.
2,816 views & 0 likes for this thread, 8 members have posted to it.
Switched to Mac
1371 guests, 177 members online
