Thread started 18 Aug 2007 (Saturday) 13:11
How is this PP done?
Swift
Aug 18, 2007 13:11 |  #1
http://martinandreasen​.dk …l/index.php?sho​wimage=316 (external link)
Just wondering how this style is done...I absolutely love his images, and would love to know how he does them!
Canon 550D | Canon 70-200mm f/4L USM | Canon 17-55mm f/2.8 IS USM | Canon Speedlight 430EX | Raynox DCR-250 Macro
Radtech1
Everlasting Gobstopper
Joined Jun 2003
Aug 18, 2007 14:02 |  #2
There is about a hundred or so shots, with a dozen or so different approaches. Please link to one, and then let's dissect it.
Rad
Be humble, for you are made of the earth. Be noble, for you are made of the stars.
Swift
Aug 18, 2007 14:03 |  #3
I did link to one?
If my link takes you back to his gallery, try this...
http://martinandreasen​.dk …022144318_db4c4​209-01.jpg (external link)
howzitboy
Aug 18, 2007 14:07 |  #4
looks tone mapped and sharpened
http://onehourwedding.​blogspot.com/ (external link)
Livinthalife
Aug 18, 2007 14:13 |  #5
howzitboy wrote in post #3750436 (external link)
can you explain how it's done though?
-Andy-
Swift
Aug 18, 2007 14:14 |  #6
Tone mapping doesn't give that dark feeling displayed in the image. All that does is bring out the clouds.
B3SEO
Aug 18, 2007 14:16 |  #7
I would think he's doing most of that in photoshop, which would be the easiest way to do it. I can think of this way to achieve that effect.
Take the pen tool and go around the leaf, right click and make a selection, and switch to the marquis tool, right click and make copy a of the selection, thereby just making a layer with what you've selected with the pen tool.
It looks like he did something similar to the hand and coat/arm holding the leaf also. Just repeat steps above to get a hand on it's own layer.
Desaturate the bottom layer (the original), either by image>adjust>desaturate or using the channel mixer (a better choice) and selecting monochrome at the bottom (checkbox) and then adjusting the r g b channels to suit your taste. Edit: (in looking at the photo once again, it appears the trees behind are a muted green, but that's easy to fix with a mask and the gradient tool.
Now you have a color copy of the leaf on it's own layer (and the hand/coat also on it's own layer), ontop of a black and white. Go to the leaf layer, and desaturate to your flavor. (image>adjust>hue/saturation).
There are probably other ways, but above is one way.
Take your time. It should come out similar.
Tone mapping won't give you the same effect.
Step back please... I'm armed with a camera...
Gear - Canon 5D/Grip, Canon 20D/Grip, EF 17-40mm, EF 24-70mm/2.8, EF 28-135mm IS, EF 50mm/1.4, EF 85mm/1.2, EF 135mm/2.0, EF 200mm/2.8, Canon 70-200mm/2.8 Canon 580EX II (3)
Other Stuff - Manfrotto Tripods/Heads, Domke bag, Pelikan Cases
Swift
Aug 18, 2007 14:19 |  #8
B3SEO, I appreciate your explanation, but would it not be easier to create a Hue/Saturation adjustment layer, then lower the Saturation to -54 or so, and then go over the parts you want to keep (everything outside the hand and leaf) saturated with a black brush.
Was this basically what you were trying to explain?
Swift
Aug 18, 2007 14:22 |  #9
Here is my try at this type of "style"
What I did was desaturate to -70 using the explanation in my post above, and add a Curves adjustment layer and choosing "Strong Contrast" in the drop down menu for the curve.
Radtech1
Joined Jun 2003
Aug 18, 2007 14:29 |  #10
Well lets see.
NOT SAYING THIS IS HOW HE DID IT, RATHER, this is how I would duplicate the result.
Assuming an appropriately exposed and focused starting shot:
1) I see an overall increase in contrast - lots of blacks, I suspect two contrast blend layers, one set to Multiply, about 20% to 50% or so opacity, and another set to Overlay - possibly slightly Gaussian Blurred, again 20% to 50% or so opacity.
2) An overall desaturation is observed. I would not be surprised if one of the above mentioned layers was completely desaturated. If not, I would achieve this by adding a desaturated layer - Normal Blend, about 20% to 50% or so opacity, possibly slightly Gaussian Blurred OR Soft Light Blend, this time 70% to 100% opacity. [Choice of Normal or Soft Light depends on what the contrast looked like before adding the desat layer].
2b) Also noted is a relative increase in saturation on the leaf and hand relative to the rest of the shot. The desaturation layer mentioned above was partially erased in the hand and the leaf.
3) The bokeh appears suddenly on the coat sleeve. This was most likely done in post. I suspect this as the focus falls off very abruptly as you look down the sleeve, however the brown lining inside the coat does not exhibit the same bokeh as a blurry area of the coat sleeve does, despite an equal distance from the camera. I commend the shooter on an excellent job selecting the leaf.
4) The leaf and (to a lesser degree) then hand demonstrate a rough sharpness and graininess that is not evident in the rest of the shot. I suspect a High Pass layer was selectively applied to those areas - more to the leaf than the hand.
5) Speaking of hand, do we know if he is in/from Europe? I notice the model's wedding ring is on her right hand. If not, the shot is flopped.
6) There is a black vignetting layer added.
Rad
CHECK THIS LINK:
http://dc27.4shared.co​m …22144318_db4c42​09-011.jpg (external link)
Swift
Aug 18, 2007 14:45 |  #11
Thank you Rad, that sounds like what he might have done.
Here's me putting your words to action:
Looks to be right :D.
Swift
Aug 18, 2007 15:35 |  #12
Wow...This action I found in this forum stickied:
https://photography-on-the.net …php?p=2733520&p​ostcount=1
Does almost exactly what Martin does!
See here:
IMAGE: http://img.photobucket.com/albums/v715/kninja0/Untitled12-1.jpg
The highlights are blown out though.
NickSim87
Sir Chimp-a-lot
Aug 18, 2007 15:56 |  #13
Very nice effect, very moody... punk/grunge senior portrait for sure.
Gear List | Feedback
B3SEO
Aug 18, 2007 16:23 |  #14
Swift1 wrote in post #3750478 (external link)
That's another way to do it. However, I'm not much for brushing back "in" color, and that would take a little longer.
Rad looks like she analyzed it quite well (again!). It's the same old addage, that theres more than one way to skin a cat.
Radtech1
Joined Jun 2003
Aug 18, 2007 16:39 |  #15
B3SEO wrote in post #3750947 (external link)
Fouth shot down.
3,792 views & 0 likes for this thread, 13 members have posted to it.
1472 guests, 132 members online
