Artur
Thanks for looking and commenting
yeah we have loads of these guys running around, there are a lot of babies too, they look pretty funny as they have huge heads.
I had previously removed the bit of garden fence to the right, but it looked unbalanced if that makes any sense, here I did a quick crop just to remove it.
| HTTP response: NOT FOUND | MIME changed to 'image/png' |
Silvex
Thanks for looking and commenting.
Yeah I had thought about the Aperture, my main constraint was the fading light and the fact I was already shooting at ISO 800.
if I had gone to f/11 I would have lost 2 stops, which would have resulted in a shutter speed near 1/15th sec.
I was already way bellow my reciprocal.
which in 35mm my lens was at 420mm (263mm x 1.6 = 420)
My minimum shutter speed should have been 1/420th to avoid getting camera shake unfortunately the next available shutter speed is 1/500th
So as you can see at 1/60th for my shutter at 263mm I think I did pretty good handheld, I definitely need an IS lens though at somepoint.
BSBXTi
Yeah I did use USM in PS CS, I used a setting of Amount 150%, Radius of 1.5 & Threshold of 8, anymore than this setting resulted in the ISO noise starting to show through, just enough to enhance detail around the eye without getting halos.
but thank you all for the CC
