Thread started 02 Jul 2004 (Friday) 17:21
Make whites bloom?
saqib
Joined Mar 2003
Jul 02, 2004 17:21 |  #1
hi,
i am trying to convert a picture from color to b&w, and the kid in the photo is wearing a white shirt - i want the shirt to 'bloom' a little.
i am using photoshop - any help please?
thanks in advance,
Saqib.
Scottes
Trigger Man - POTN Retired
Joined Nov 2003
Jul 02, 2004 17:58 |  #2
I'm not sure what you mean by "bloom." I think flowers blooming, opening up, so do you want the shirt to "move" - that is, change the shape?
Or do you wish to do something with the color? This also makes me think "glow."
You can take my 100-400 L away when you pry it from my cold, dead fingers.
Scottes' Rum Pages - Rum Reviews And Info (external link)
Follower of Fidget - Joined the cult of HAMSTTR©
CanonUser
Joined Sep 2003
Jul 02, 2004 20:13 |  #3
If you mean having the shirt glows like the old soft focus trick then try this:
1/ Complete all adjustment as needed.
2/ Select the final image, press Control+Alt+~ to select the hilight areas.
3/ Press Ctl+C to copy.
4/ Create a new layer, then press Ctl+V to paste the hilights into this layer.
5/ Blur the hilight layer (Blur 1) with Gausian Blur, be heavy handed with the setting.
6/ Duplicate this blurred layer (Blur 2).
7/ Reduce the opacity of Blur 1.
8/ Change Blur 2 blend mode from Normal to Screen.
9/ Reduce the opcaity of Blur 2.
Adjust the Blur 1 & 2 opacity to your taste. If wanted, you can put a mask on Blur 2 to restrict the "Bloom" effect to the shrit only. Mask Blur 1 to control the soft focus.
Good Luck,
Alan
whowie
Joined May 2004
Jul 02, 2004 20:41 |  #4
After you select the highlights, Control-Alt-"~", then just press Control-J and the highlights will automatically be pasted to a new layer. Saves a couple of steps.
http://www.flickr.com/​wesleyhowie (external link)
Canon EOS 70 D, Canon EOS 30D,150-600mm F/5-6.3 Di VC USD SP, assorted lenses, flashes, filters, bags, tripods, some film gear, etc. etc.
saqib
Joined Mar 2003
Jul 03, 2004 14:31 |  #5
by bloom i basically mean like making it almost bleed and appear really bright. bloom is a word coined from setting up tv systems using THX optimizer (found on some dvds) - when adjusting the brightness, some of the white squares 'bloom'.
thanks for the advice - i will let you know how i get on :)
2,057 views & 0 likes for this thread, 4 members have posted to it.
Make whites bloom?
502 guests, 140 members online
