Thread started 20 Aug 2007 (Monday) 01:21
Tip - Lab mode
Damo77
Aug 20, 2007 01:21 |  #1
I know there's a school of thought surrounding the benefits of editing in Lab mode. I don't bother with it, RGB mode serves my needs quite well.
However, I used to convert to Lab mode every now and then, if I wanted to majorly adjust luminance without affecting colour. I'd make my adjustment using Levels or Curves, then convert back to RGB.
However, converting to and fro isn't convenient, nor is it good for the file. If you're an occasional Lab converter like I was, try this instead.
I simply duplicate the layer I'm working on, then change the layer mode to "Luminance". Then my Levels or Curves adjustments behave like Lab mode! Once I've finished, I simply merge the layers again.
I'm sure this is obvious to most of you, but if it helps somebody ...
Damien
Website (external link) | Facebook (external link)
ayotnoms
Perfect Anti-Cloning Argument
Joined Jan 2005
Aug 20, 2007 01:46 |  #2
Hello my name is Steve and I am a serial LAB converter
...for purposes of sharpening the lightness channel, adjusting luminance, and other fun things such as noise reduction.
Your tip may be obvious to others but it's news to me...although makes total sense.
I'll be sure to give it a whirl.
Cheers!
Steve
[URL="http://photograp​hy-on-the.net/forum/showpost​.php?p=1267612&postcou​nt=17"]Gear
Damo77
Aug 20, 2007 02:01 |  #3
Hi Steve, similar tip for noise reduction. Dupe the layer, change it to Color mode. Then blur it. Magic!
Damien
tzalman
Fatal attraction.
Aug 20, 2007 02:24 |  #4
http://www.luminous-landscape.com/essays/c​urves.shtml (external link)
Elie / אלי
Picture ­ North ­ Carolina
Gaaaaa! DOH!! Oops!
Aug 23, 2007 08:05 |  #5
Good stuff. thanks.
1,349 views & 0 likes for this thread, 4 members have posted to it.
Tip - Lab mode
1063 guests, 104 members online
