Thread started 20 Aug 2007 (Monday) 12:59
UWA vs. stitching images (includes six 225x150 images)
jylitalo
Joined Mar 2004
Aug 20, 2007 12:59 |  #1
Finnish version of this text is available in http://jylitalo.homeip​.net/blog/?p=104 (external link)
However, here is english version, for those who don't understand finnish.
During last weekend, I made some experimentation on whether or not it would be possible to replace UWA lens with more normal focal range and simply take multiple potraits and combine them as landscape (or reverse), when you just want to grab maximal field of view.
Experimentation covered shots on three separate locations with Canon EOS 20D + Tokina's 12-24/4 lens. UWA part was done at 12mm and 24mm was used as "normal" focal length, since 35mm's field of view seemed to be bit too narrow for the job. Locations were Senate's Square, Railway Station and Kiasma in Helsinki.
Before the test, I would like to note that UWA is hard to replace, if
- you need that focal length for shooting moving subjects,
- you want to use polarizer and/or GND on lens
- you don't want to do any cropping afterwards
- you don't have time for postprocessing
- you need to play with UWA lenses perspective
My work flow for stitching images was following:
- lock WB in camera to sunny or something else than AWB
- take multiple readings and select shutter speed for f/8 aperture
- set camera into manual with f/8 and wanted shutter speed
- take shots
- use BibblePro to transform RAW into JPG
- use hugin to stitch images and save result into JPG
- use BibblePro to crop image into 3:2 (or 6x4) format.
This is bit more complicated, but until they write PhotoShop for Linux ... (or I switch my photoediting to my Mac Mini).
Now the part that most of you have probably been waiting for:
IMAGES
Senate's square (@12mm vs. 3x@24mm)
Railway station (@12mm vs. 4x@24mm)
Kiasma (@12mm vs. 4x21mm)
(images are links to higher resolution images (720pix on long side))
MY CONCLUSIONS
Based on these results, Kiasma was nice exception for UWA lens. Part of it will probably go for the fact that I accidently used 21mm focal lenght instead of 24mm, but even bigger part is probably due to fact that I was standing quite bit higher than where the foreground is (look at the shadows in lower right corner to get an idea).
On Senate's square, the ground before the church is damn boring and in railway station things are falling into center. Then again stitched images from railway station is far from perfect as well. I thought that I would easily get those two stone figures on the left side into image. However as you can see, my stitched image has black corner on bottom left corner.
If I would have to back to one these spots and make image for some agency, company, etc. I would probably do it by stitching images together, because to my eye, they provide better image about the location. Only downside is that image will take whole lot more work, but if its paid job ...
- Juha - ylitalot.com (blog (external link), portfolio (external link), gear list (external link), etc.)
Raphael ­ Emond
Aug 20, 2007 13:56 |  #2
For me, the main advantage of stitching, is when you need a high megapixel count for a big landscape print. Or, you want extreme angles, like 180°+ images.
I've done a 360° horizontal x 120° vertical panorama and it was weird!
And remember, even if you stitch 24mm images to have the same FOV of a 12mm,
you wil not have the same perspective. Sometimes, you need the effect of 12mm some times you don't. It's a matter of what you want in your picture.
But Congratulations, your stitch are very good! And demonstrate easily the main difference between 12mm and 24mm
Canon Rebel XT, BG-E3, Sigma 12-24 EX DG HSM, 28/2.8, 50/1.8, 24-105L IS USM, Sigma 70-200 2.8 EX DG HSM
420EX, Sigma 1.4X Converter, Moded Off-Shoe Cord 2, 2x1Gb + 1x2Gb, Pelican 1550 Case, Hoya IR72, Mono-Tripod.
Scottes
Trigger Man - POTN Retired
Joined Nov 2003
Aug 20, 2007 16:04 |  #3
Stitching gives more pixels.
Stitching can give you *fits* if you have parallax issues, so...
Stitching can be a pain requiring more expensive gear like a pano head (or limiting your shots, since you won't be able to take every shot you see without a pano head).
So.... UWA unless you need the pixels for printing.
And note that I do a decent amount of multi-image stitching, so I'm very familiar with what goes into it. In a nutshell I think that UWA is 5-10 times easier, and much more likely due to the parallax/pano-head issue.
But nothing beats a 220-megapixel print.
You can take my 100-400 L away when you pry it from my cold, dead fingers.
Scottes' Rum Pages - Rum Reviews And Info (external link)
Follower of Fidget - Joined the cult of HAMSTTR©
chauncey
Aug 20, 2007 16:19 as a reply to  @ Scottes's post |  #4
I use CS3 and photomerge is my favorite feature after ACR 4.1. I use it to increase pixel count, more images zoomed in. The technique allows me more room to crop, which my left side brain needs.
CS3 makes up for a lot of poor technique, you can handhold with an IS lens.
1,783 views & 0 likes for this thread, 4 members have posted to it.
1730 guests, 172 members online
