Thread started 21 Aug 2007 (Tuesday) 08:42
Questions on 350d and 30/40d
alankey
Aug 21, 2007 08:42 |  #1
Hey everyone,
Just got a few questions on the 350d and 30/40d.
1. Whats the resolution power on the 350d? How many bits?
2. Is there much difference in image quality between the 350d and the 30d?
3. Much difference in the level on noise between the two?
4. Does the 30d focus noticably faster and more accurate than the 350d?
I've probably got more quesstions that ive forgot but i'll add em here if i remember, and i searched abit and have gotten some of the answers i just want to confirm.
Alan_____________
40D, Sigma 10mm f2.8 Fisheye, Canon 24-70 f2.8L, Canon 70-200 f2.8L + a bunch of flashes:)
StewartR
"your nose is too big"
Aug 21, 2007 09:46 |  #2
1. Twelve bits.
2. No.
3. No.
4. Yes.
www.LensesForHire.co.u​k (external link) - complete with matching POTN discussion thread
Photos: Cats (external link) | London by day (external link) | London by night (external link) I My POTN photo sharing threads (external link) | Official "Where Am I Now?" archive (external link)
Gear: 350D | Sigma 18-200mm | EF-S 10-22mm | EF 50mm f/1.4
nicksan
Man I Like to Fart
Aug 21, 2007 09:47 |  #3
StewartR wrote in post #3767295 (external link)
1. Twelve bits.
2. No.
3. No.
4. Yes.
Succinctly put...:D
gjl711
Aug 21, 2007 10:01 |  #4
1. Twelve bits.
2. No.
3. No.
4. Yes.
nicksan wrote in post #3767305 (external link)
Succinctly put...:D
Of course you can change the XT to an XTi and make it
  • 12bits
  • no
  • no
  • no
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
push
Aug 21, 2007 10:08 |  #5
I know someone with an XT and my 30ds high iso performance is better (iso 800+ slightly noticeable at 400)
Canon ­ Bob
Aug 22, 2007 15:45 as a reply to  @ push's post |  #6
I've got all three....XT, XTi and a couple of 30D's
I think the 30D and XTi have the focus speed advantage,
The 30D and XT win the noise stakes.
The 30D wins the features stakes
The XTi is my preffered macro camera (handheld)
Pro's and con's for each of them but the 30D takes the honors if you're panning with longer L's mounted...the others can't compete there.
Bob...all IMHO, of course
1Dx2 (2), 5DSR, 1Ds3, 1D4, 5D2(590nm), 5D2(720nm) EF600 EF400 EF300-II EF300 EF200 EF200-II EF180L EF135L EF100 EF85-II EF50L TS-E17/4 TS-E24L-II TS-E45 TS-E90 MP-E65 EF70-200-II EF24-70/2.8-II EF16-35/4 EF8-15/4 EF11-24/4 Zeiss 15/2.8 21/2.8 25/2 28/2 35/1.4 35/2 50/2 85/1.4 100/2 135/2 T/C's L-SC & a WIFE!
alankey
Oct 04, 2007 19:54 as a reply to  @ Canon Bob's post |  #7
thought i dig up this thread rather than start another.
Just want to make sure the peripheral focus points on the 30d dont go cross sensitive at any f. stop, correct?
I know its on here some where i just cant find it.
Alan_____________
JackProton
Oct 04, 2007 22:41 |  #8
I think you mean you just want to use the center focus point alone when using an f2.8 or faster lens.
alankey
Oct 05, 2007 02:28 as a reply to  @ JackProton's post |  #9
no, i want to know if the peripheral focus points go cross sensitive at any certain apeture or if they dont.
Alan_____________
JackProton
Oct 05, 2007 03:09 |  #10
Oh, I see. As I recall...
The 300D and 350D/XT have no high precision focus points.
The 400D/XTi and 30D have one high precision focus point - the center point - which adds high precision focus when used with lenses of f2.8 or faster. "Additionally, the center AF point has a vertical-line sensitive sensor compatible with f/5.6. Therefore, cross-type focusing is possible with any EF lens." (http://www.robgalbrait​h.com …Rebel_XTi_White​_Paper.pdf (external link))
The 40D has "9 cross-type sensors, and world's first diagonal high-precision cross-type AF at center point with f/2.8 and faster lenses". (from http://www.usa.canon.c​om …39&modelid=1565​3&pageno=3 (external link)) According to dpreview:
A key advancement of the EOS 40D is its new 9-point cross-type AF system. All nine AF points can achieve focus on both horizontal and vertical planes. A central AF point is capable of accurate focusing up to aperture f/2.8, with eight outer points working up to f/5.6.
Overkill
Oct 05, 2007 05:03 |  #11
Hmmm
350D and 30D have different Sensors. 30D 8.2 eff 350D 8.0!'
30D has a slight advantage in noise control over the 350D
30D is far better build!
30D Has more usefull features!
30D has faster and more accurate focus!
A lot of people think that the CMOS sensor is the same... but thats a mistake!
And yes you can make a lot of good pictures with the 350D and 30D!
Canon EOS 40D Gripped / 20D Gripped, EF 70-200 2.8L, [COLOR=black]EF 100-400 IS USM L, EF-S 17-55 2.8 IS USM, EF-S 10-22 USM, Sigma 105mm 2.8 EX Macro, Kenko 2XTC DG Kenko 1.4TC DG, Kenko Extension Tubes DG 12-20, Canon Speedlite 580EX, Manfrotto Tripod!
mcmadkat
Oct 05, 2007 07:23 |  #12
The sensor could well be the same one, Canon have cut down the pixels on the 350D compared to the 30D.
350D = 3456 x 2304 = 7.96MP
30D = 3504 x 2336 = 8.19 MP
In the real world I found no image difference, although 30D noise control seems better.
30D AF is lightyears ahead of the 350D.
30D 17-40L 580EXII
https://photography-on-the.net/forum/showthre​ad.php?t=386249
Overkill
Oct 05, 2007 11:28 |  #13
mcmadkat wrote in post #4068643 (external link)
The Sensor is not the same....
They both have the same dimensions but the 30D has a higher pixel density!
A different isolation of the pixel to improve the higher ISO Expansion and
better ISO (high) performance.
You cant just turn of a bunch of pixels to go from 8.2 tot 8.0 MP!
Jon
Joined Jun 2004
Oct 05, 2007 14:35 |  #14
alankey wrote in post #4065921 (external link)
Correct. The only cross-type AF sensor on the 30D is the center point. The others are either horizontal or vertical.
Jon
Cocker Spaniels
mike397
Oct 06, 2007 11:10 as a reply to  @ Jon's post |  #15
Jon,
So,it is the same on the 40D ,correct?
Correct me if I'm wrong .
Mike
Canon 24-105L ,,Voigtlander 40mm & Apo Lanthar 90mm macro...,Nikon 55mm f2.8 micro ,Leica 60mm f2.8 macro ,Leica 180mm f4, Zeiss c/y 135mm f2.8 ,Olympus 21mm f3.5
http://mike397x.zenfol​io.com/ (external link)
2,117 views & 0 likes for this thread, 12 members have posted to it.
2777 guests, 166 members online
