Thread started 21 Aug 2007 (Tuesday) 12:06
crop factor vs megapixels
gasrocks
Aug 21, 2007 12:06 |  #1
I'm sure there is a formula for this, or an easy way to figure it out. Camera A has X mp and a crop factor of Y. Camera B has W mp and a crop factor of Z. How do you compare the images from each? Example, the 5D vs 20D/30D, the 1.6x crop cameras win over the same image from the 5D (since the one from the 5D would cover less mp.) Sorry if I am not making my quesiton clear enough. I'm thinking about the new 40D and 1Ds3, of course (and how to compare them to other bodies.)
Jon
Joined Jun 2004
Aug 21, 2007 12:11 |  #2
Compare X*(Y^2) to W*(Z^2). Whichever is bigger wins the pixel density "beauty contest". The numbers you'll get are the approximate number of pixels/MP of a full frame sensor of the same density.
Jon
Cocker Spaniels
ScottE
Joined Oct 2004
Aug 22, 2007 22:15 |  #3
The only way to really compare images is to make prints and place them side by side.
If competent photographers, image processors and printers make both prints there is surprisingly little difference.
Mathematics doesn't really show what the eye will see.
AJSJones
Gallery: 6 photos
Joined Dec 2001
Aug 22, 2007 22:33 |  #4
gasrocks wrote in post #3768128 (external link)
I think you will need to be a tad more specific in your question before you get any real help!
My picture galleries (external link)
Billyj571
Aug 23, 2007 07:40 |  #5
Is it worth the extra $1000.00 bucks for a ff sensor?????????
Richard_Miami
the windbag plateau
Aug 23, 2007 08:09 |  #6
Billyj571 wrote in post #3780353 (external link)
To some, yes - to others, no. It's just choices- as we used to say "different strokes for different folks"
I am the crispy noodle in the vegetarian salad of life
Gear
RSPhotoGallery.com (external link)
morehtml
Aug 23, 2007 09:35 |  #7
I just got the hang of this too.
Here is the easiest way. figure the pixels per sensor mm (max pixel length/max sensor length in mm). The higher the number the more pixels 'on target' you get. Of course the crammed pixels may give up quality to noise, etc.
So here you go in order (pixels per mm)
Lowest pixels on target
121 - 5D (example 4368/36=121)
122 - 1D MK IIN
135 - 1D MK III
138 - 1Ds MK II
155 - 20D/30D
156 --1DS MK III
175 - XTI and 40D
highest pixels on target
"Allen's Visions of Nature Gallery" (external link)
www.allensvisions.com (external link)
more glass than I need
Curtis ­ N
Master Flasher
Aug 23, 2007 09:37 |  #8
Beyond the math, photography is recording light. The more light you record, the better images you can make.
The 30D and the 1DsMkIII have similar pixel density. For the sake of argument let's assume that they will give you similar noise characteristics at a given ISO. But if you take a the 21mp image and downsize it to 8.2mp you will dramatically reduce the noise and still have the resolution of a 30D.
Larger format means recording more light to create better images. It's true whether you do it with bigger photocells, or more photocells, or some combination thereof.
morehtml
Aug 23, 2007 09:53 |  #9
Then there is the 'technology' behind the pixels so for instance the 40D's pixels should be far superior to the XTI's pixels and a lot less noise.
Curtis N wrote in post #3781036 (external link)
gjl711
Aug 23, 2007 09:53 |  #10
morehtml wrote in post #3781028 (external link)
95 - D30
122 - 1D MK IIN
135 - 1D MK III
135 - Rebel/300
138 - 1Ds MK II
155 - 20D/30D
156 --1DS MK III
175 - XTI and 40D
569 - S5 ....
And to jsut confuse you even more, I added a few. Clearly shows that pixels per MM though is a metric, it does not tell the whole story. :)
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
morehtml
Aug 23, 2007 09:56 |  #11
gjl711 wrote in post #3781150 (external link)
Well in Canon's new line MK III, 1DS MK III and 40 D the technology behind the sensor is similar so the 40D would put more pixels on a small target (A bird for example) than the others at a cost of possibly more ISO noise.
AJSJones
Gallery: 6 photos
Joined Dec 2001
Aug 23, 2007 11:20 |  #12
The venerable 1D was only 87/mm :D So many people still love that camera - those buckets captured lots of photons!
StewartR
"your nose is too big"
Aug 24, 2007 03:55 |  #13
Pixels per duck is the accepted measure on POTN, I believe.
Visualisations like this one (which I need to update to include the newest models) show that the 400D gives you more PPD than any other DSLR in Canon's range.
www.LensesForHire.co.u​k (external link) - complete with matching POTN discussion thread
Photos: Cats (external link) | London by day (external link) | London by night (external link) I My POTN photo sharing threads (external link) | Official "Where Am I Now?" archive (external link)
Gear: 350D | Sigma 18-200mm | EF-S 10-22mm | EF 50mm f/1.4
5,131 views & 0 likes for this thread, 10 members have posted to it.
1467 guests, 137 members online
