About a month ago I bought a second-hand 10D as a spare body. It was sold to me as faulty because every second or third shot would result in the ever so helpful "Error 99" (don't worry, it was cheap). After reading several threads on here I naturally assumed this was a shutter fault. The fact that the previous owner said he'd taken about 80,000 shots seemed to confirm this.
Anyway, after playing around with the camera for a little while I noticed that if I hold the mirror in the lifted position while releasing the shutter, the error doesn't occur.
I sent the camera to a repairer to get a quote with an explanation of the fault and my own findings. A week later they came back to me with a quote for the repair of about AU$400 and mentioned that the shutter would need to be replaced.
I have since contacted Canon about pricing for parts... The shutter (Part#CG2-0961) can be shipped to me for under AU$70... I guess there's a lot of labour charges in that repair! That being the case I thought I'd do it myself since I consider myself fairly good at repairing mechanical faults. Plus I have found a bunch of info on disassembling a 10D which will help.
Question... if it is the shutter, why does it work fine when I keep the mirror lifted? Is there some linkage between the shutter actuator and the mirror? Have the repairers just got it wrong?
While I was on the phone to Canon, I asked the cost of a new mirror box assembly (part#CY3-1432) because to me it sounds more like a problem with the mirror than the shutter. That is about AU$230 shipped to my door. If it were to be replaced by the repairers, it would cost major money and be a pointless excercise (I could likely buy a working 10D for much less)
I guess, for the moment I'll go with doing a shutter replacement and if that doesn't fix it I'll consider replacing the mirror box.
Has anyone had any experience with a failed shutter and how the mirror would affect it?
One other thought is that the mirror actuator might be clogged up... the previous owner used it for nightclub shooting so there's a possibility it may be gummed up with tar from cigarette smoke. I've had to clean that crap off stuff before and I can certainly see it causing issues in small mechanical parts. The camera did smell like cigarettes when I first got it...
