Thread started 26 Aug 2007 (Sunday) 20:46
The 430EX or 580EX II for macro?
hfgerena
Aug 26, 2007 20:46 |  #1
Hello everybody;
I have one question; Does anybody out there use the 430EX or 580EX II for macro photography? Do you recomended?
I don't want to spend my money on a new flash that works only for macro (a dedicated flash for macro). With the 430 or 580 I could have more options.
hfgerena.
Canon 7D/wg; 35 L f/1.4 * 17-40 L f/4 * 24-105 L f/4 * 70-200 II L f/2.8 * 300 L f/4 * Canon EX 1.4 III * Sigma 180mm Macro f/2.8 * Sigma 8-16 * Canon 430 EX III-RT
skylab
Aug 27, 2007 02:36 |  #2
Well I use the 430ex, on a bracket with a clip on diffuser. Also I have a home made diffuser that I use. It works for me ok.
Brian :-D
racketman
Gallery: 20 photos
Aug 27, 2007 04:54 |  #3
probably 430ex to keep weight down, recycling time not usually a factor with macro.
Toby
devil350
Aug 27, 2007 06:12 |  #4
+1 for the 430EX too.
Cheaper and lighter than the 580EX and enought to do quite good Macro with a bracket.
Ciao,
Laurent.
MY Gear List | My Gallery (external link)
Attic
Aug 27, 2007 06:16 |  #5
The 430 will be find as you don't need the extra power of the 580 unless you are going to do other stuff that needs more power.
Alby
nan3182
Aug 27, 2007 11:15 |  #6
Another vote for the 430EX on a flexible bracket, but I would rather have the MR-14EX :)
Nan
tomd
Aug 27, 2007 11:22 |  #7
nan3182 wrote in post #3805963 (external link)
What about recommending a bracket as well? I have a 430 already, what else do I need to get the light where I need it? A bracket of some sort (maybe brand or even a B&H link), extension hot chord? other?
=======>>> play W.A.I.N. :D
racketman
Gallery: 20 photos
Aug 27, 2007 11:42 |  #8
off camera shoe cord http://www.bhphotovide​o.com …C_E3_Off_Camera​_Shoe.html (external link)#
bracket http://www.bhphotovide​o.com …lip_Flash_II_Br​acket.html (external link)
Toby
tomd
Aug 27, 2007 11:57 |  #9
Thanks toby, exactly as I was looking for!
tom
racketman
Gallery: 20 photos
Aug 27, 2007 12:00 |  #10
actually the 7" bracket is probably more practical - and cheaper!
http://www.bhphotovide​o.com …Flip_Flash_I_Br​acket.html (external link)
Toby
Mrvile
Aug 27, 2007 12:36 |  #11
430EX user here...I like it because it's light and it has an amazingly fast recycle time.
Eric
Canon EF 70-300mm f/4-5.6 IS USM Review
nan3182
Aug 28, 2007 10:57 |  #12
tomd wrote in post #3806205 (external link)
tom
Sorry I forgot to add that I have all the links to the equipment I use in My Gear in my sig. I tried to incorporate both where to buy and reviews.
The 7" is fine if you using your 100mm macro with all your tubes but any longer than that and (at least) I find it lacks in reach. But that is just me.
Nan
racketman
Gallery: 20 photos
Aug 28, 2007 11:47 |  #13
nan3182 wrote in post #3813366 (external link)
not sure what you are suggesting here - the 18" Delta I presume but are you likely to have a longer set up than that you have described?
Toby
scot079
Aug 28, 2007 12:27 |  #14
Here's a vote for the 580 II. Actually, it really only suits MY needs. I use a $5 PC cord to hook to the camera instead of the more expensive (not sure how much) Off-Shoe Cord, since I already had the flash anyway. But, alas, it is heavy, and quite a bit more expensive. Still, it's found it's home on my rig
IMAGE: http://i170.photobucket.com/albums/u264/scot079/IMG_4064.jpg
- Tim
www.timadkinsphoto.com (external link)
GEARandFEEDBACK
nan3182
Aug 28, 2007 16:43 |  #15
racketman wrote in post #3813635 (external link)
Yes, your presumption is correct. Right now I am using my 70-300 (5.6" long) as my "macro" lens with a full set of Kenko Tubes, it is a bit longer than a 100 macro (4.7" long) with a full set of tubes. I personally find that with the 70-300 and the tubes mounted the reach of the 7" Delta Bracket is a bit short, not unusable but a bit short, when I use the zoom to help get focus while trying to maintain a certain distance from a flighty insect. To me a longer setup would also include adding additional tubes, a TC, and using a hood. Two weeks ago I had rented the 100 macro and was using it with my 7" Delta Bracket and Kenko Tubes and I found the combination wonderful, and enough play to try some interesting lighting set ups. Personally I own the 7" Delta Bracket and would for the $30.00 it is recomend almost anyone to own one. I have not had the pleasure of working with the 18" Delta Bracket I am sure it would be useful to anyone with a longer setup (as previously described) and something to keep in mind before making a purchase.
Nan
3,827 views & 0 likes for this thread, 10 members have posted to it.
2798 guests, 141 members online
