Thread started 28 Aug 2007 (Tuesday) 03:23
Pro show to DVD - Why is it not the same as preview?
C.Steele
Aug 28, 2007 03:23 |  #1
Ok, I'm fairly new with Pro Show and I think I might understand what's going on here. I need help to get through it though.
I make a new show. Set the motion effects to randomize across all slides. Set transitions to randomize as well. I preview the show. I see a few spots where the motion effects cut a little too deep into the pic and chop heads off and such. I then go in and adjust those individual slides to correct the problem. I preview the show again - everything looks great.
I burn to show to DVD. I pop it in the DVD player and watch it on my TV. It looks horrible. It's like everything has expanded. Lots of chopped off heads.
Ok, I think what's happening here is I notice when I adjust the motion effects there is a semi-transparent mask on the top and bottom of the frame. I'm guessing this might be showing where the boundaries for TV are? Seems logical. So the question is - How do I keep the motion effects inside those parameters without hand adjusting each slide? The randomization seems to ignore them. Is there a way I can set a preference somewhere to randomize motion for DVD output?
I'm a little frustrated here and I need to drop off this DVD tomorrow night. What's the best way to go about solving this problem? Heeeelp:confused:
Chris
Sometimes I do get to places just when God's ready to have somebody click the shutter. -Ansel Adams
Portland Wedding Photographers (external link) | Steele Photography (external link)
PlayMits
Aug 28, 2007 04:00 |  #2
I think your images are to big, on dvd slideshow software there is normally a safe working area displayed in the viewing area, to stop your images from being chopped off.
I'm not 100% as I have not used that software.
EOS20D, EOS50D 18-55mm EF-S, 17-85mm is EF-S 75-300mm EF, 100-400mm is L EF Lens
EOS_JD
Aug 28, 2007 04:22 |  #3
C.Steele wrote in post #3811451 (external link)
Chris
there's a setting in proshow to "fit to safe zone" which will resolve this when viewing your slideshow on a TV. That transparent mask is indeed the safe area and if you want your images to show correctly on a TV this is the maximum area your TV will show. If you don't want to view on a TV, you can safely use the whole area.
Also if you are viewing on a 16:9 TV you need to burn the video as a 16:9 show. Anything else will stretch your video and you'd need to maybe set your TV to 4:3 to view correctly.
These settings are in the menus.
All My Gear
5D MkIII & 5D MKII + Grips | 24-70 f2.8L IS | 24-105 f4L IS | 70-200 f2.8L IS MkII | 50 f/1.4 | 85 f1.8 | 100 f2.8 | 1.4x MkII | Tamron 17-35 f2.8-4
C.Steele
Aug 28, 2007 12:20 as a reply to  @ EOS_JD's post |  #4
Thanks for the replies!:cool: All is well.
Chris
pigtailpat
Aug 28, 2007 12:50 as a reply to  @ C.Steele's post |  #5
There's a yahoo group on both proshow and it's big brother producer, at Yahoo Groups. Do a search you'll find it. That's a more appropriate place for pro show questions, because there are more knowledgeable people generally there (insofar as proshow and producer are concerned) than here on POTN.
Hope this helps you.:D
1D-IIN, 30D, sigma 120-300, 24-105 IS f4 L, 70-200 IS f2.8 L, 50 1.4, 580 EX, Bogen 680B/3229
EOS_JD
Aug 29, 2007 13:33 |  #6
pigtailpat wrote in post #3814017 (external link)
Proshow is the name of the software and there are 2 variants. Proshow Gold is generally for home use and Proshow Producer is for pro use. Both excellent at producing slide shows.
All My Gear
corporallouis
Aug 29, 2007 13:46 as a reply to  @ EOS_JD's post |  #7
THIS site below is the place you should hang around for a while. These folks are THE BEST.....!
http://www.proshowenth​usiasts.com/ (external link) The Yahoo groups have a lot of the same folks too, but this forum is MUCH more in depth. They readily share a wealth of information and member created files to use with the ProShow applications. Come to think of it.....a lot like this forum we're on right now .....:lol:
Canon XTi with grip, Canon 5D and BGE4 Grip, Canon 70 - 200 f4 L, Canon 100-400 L IS, Canon 24 - 105 f4 L IS, Canon EF 100mm f2.8 USM Macro, Canon Flash 580 EX ll , Hasselblad 500 C/M, Tele-Rolleiflex TLR 135mm, Manfrotto 055XPROB / 488 RC2 head, Manfrotto 681B monopod
953 views & 0 likes for this thread, 5 members have posted to it.
1118 guests, 120 members online
