I just ran into this problem. I don't know if I have set some settings wrong since I just upgraded from CS2 to CS3. Here is the problem. The picture on screen shows what I have done to the picture and then I click on File-Save for web & devices, chose JPEG option, quality high, progressive and the finished product (color) turns out different than what the original picture was. I have tried many pictures in different format, raw, jpeg and all the same thing. CS2 never did that. Any ideas? Please see picture below.
I forgot to mention that if you do a save as, the picture is fine.
I thought I could fix this by right click on the picture when in the 4-up section (after you click on save for web and devices) and change it from uncompensated color to standard windows color. The picture then changed to original color but after the save, the color turns out different again. Please help....Tks
original picture.
![]() | Byte size: ZERO | Content warning: BLACKLISTED URL |
Saved for web and devices
