Hey,
I just brought these tubes of Ebay, i can manual focus fine but i cn change my Apt, i'm using a 400d.
Any ideas..........
BOUNCINGNRG Goldmember 1,794 posts Joined Aug 2007 Location: a way around the world More info | Aug 30, 2007 15:46 | #1 Hey, London Wedding Photographer
skylab Goldmember 3,473 posts Joined Apr 2007 Location: Dudley West Midlands UK More info | Aug 30, 2007 15:53 | #2 You won't be able to change your aperture because these ring do not have pass through contacts to connect to the lens. You need Kenco tubes. Brian
jorl Senior Member 594 posts Joined Jul 2007 Location: Sarnia, Ontario, Canada More info | Aug 31, 2007 22:17 | #3 Hey, i can tell you how to do this.. if you want a specific aperture... (take off your extension tubes before doing this with just the lens on camera) what you do is set your f stop. then push your stupid depth of Field test button while holding that down, you need to take your lens off. after you do this your aperture will be closed down to what you have set it to.. then put your extension tubes on the body then put the lens ontop of them and shoot away. once you put the lens only back on the camera it will open back up. it works good.. FOR SALE: Brand new Nikon 50mm 1.4G - Msg me for details
LordV Macro Photo-Lord of the Year 2006 More info | Sep 01, 2007 01:21 | #4 jorl is correct you can pre-set the aperture of the lens using that method. Only problem is a slightly dim viewfinder. As Brian said if you want control of the aperture you need an set of auto tubes such as kenko or Jessops in the UK or pro-optic (Adorama) in the US. http://www.flickr.com/photos/lordv/
| Latest registered member was a spammer, and banned as such! 2803 guests, 141 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
