FORUMS Canon Cameras, Lenses & Accessories Canon G-series Digital Cameras
Thread started 10 Jul 2004 (Saturday) 13:13
hoodman h-dcr lcd viewfinder review
s00pcan
Joined Dec 2003
Jul 10, 2004 13:13 |  #1
Two weeks ago I was out on some sand dunes taking pictures of my family riding 4 wheelers and noticed I couldn't see the lcd on my G3 at all. So when I got home I started looking at film slr cameras because I wanted a good viewfinder. Instead I bought the hoodman h-dcr lcd viewfinder and recieved it today.
It is made of soft rubber with a plastic 2x magnifier. It collapses down so it's more compact when you don't need to use it. Bad part about the design is that the rubber isn't very sturdy. When you press your eye against it it will move, so doesn't help as much as it should for getting less shaky images. Also, the sides are a tight fit for the g3's screen, and if the sides are bent in you won't be able to fully see some of the settings.
It comes with a strap to connect it to your camera that can either be set horizantally or vertically. I'm guessing it's 2mm thick, plus the notches. You can cut the extra cord off. Even a small string keeps the swivel screen from folding back into the G3, and this doesn't even come close. It barely closes enough to make the screen flip back from self portrait (mirrored) mode. I haven't tried velcro yet.
Ok the view inside it. Yes, you can see the pixels, but they're not huge. It completely blocks out other light (I didn't even notice my flash going off). It's sharp enough to judge manual focus accuratly and use a polarizer.
If you want one, get it where I got it: http://stores.ebay.com​/Ipkus-Imaging (external link) for $20 w/ free shipping. Alternatives are the digifinder and extend-a-view. I just got this today, so I'll post again after I put it to real use. Ask if you want to know something about it.
Leighow
Joined Jan 2002
Aug 07, 2004 16:28 |  #2
Sounds like a useful feature -- they used to be only a "shade".
May I also suggest (and I don't have yet) .. some kind of lens shade. I KNOW that if your light has you "in the hood" -- the lens needs to be shaded too -- just a learned bit of advice . I may use an umbrella-- but then I don;t use a tripod.
s00pcan
Joined Dec 2003
Aug 07, 2004 17:37 |  #3
I just got a 420ex and all that light bouncing around causes more flares that I had with the internal flash. I probably do need a lens hood now.
Leighow
Joined Jan 2002
Aug 07, 2004 19:30 |  #4
Well I am an outdoors guy and I suspect that I am having lots of trouble with the sun -- especially when I shoot outside the magic hours.
Good luck .. for $19 looks like a deal!
2,146 views & 0 likes for this thread
Latest registered member is Benas
729 guests, 343 members online
