Thread started 03 Sep 2007 (Monday) 16:36
Preying Mantis / Stick bug macros
Samdiver74
Sep 03, 2007 16:36 |  #1
Hi all
Here are some macros from a shoot I did yesterday of a stick bug / praying Mantis,
total length of this guy is 2in.
these are the first two pics for the series but I have more I'll post in just a little bit, after I PP.
CC welcome
Pic 1
Pic 2
Allan
7D, 7DII, 10-22mm, 100-400, 50mm 1.4, MP-E 65mm, Sigma 150-600mm Sport, TC-80N3, 580EX, 580EX II ST-E2, OC-E2, 3021 BPro, 488RC4, Kenko EF/EFS ext tubes, The Ultimate lightbox system & Delta flip flash bracket & various lighting accessories.
http://allanmorris​.my​portfolio.com/ (external link)
racketman
Gallery: 20 photos
Sep 03, 2007 18:32 |  #2
f5 has given a very narrow DOF but #2 isnt too bad.
Toby
Samdiver74
Sep 03, 2007 19:34 as a reply to  @ racketman's post |  #3
Toby (RM)
Yeah I used the widest aperture on the main lens but I stopped down the aperture on the Reversed 50mm, it was set at f/8, I then manually actuate the the aperture lever on the FD reversed lens, via an extension I made with a coat hanger and wrapped with heat shrink.
I know I need to use the FD wide open and control aperture via the main lens, but I am so used to using the aperture lever on the reversed lens especially as I like to use just the 50mm reverses direct to camera.
But thanks for looking and the CC
it is very much appreciated.
Here are a couple more
Pic 3
Pic 4
Pic 5
Allan
Deckham
Sep 03, 2007 19:39 as a reply to  @ Samdiver74's post |  #4
Nice #2 shot.
It is a Praying Mantis.
A Stick Insect is not a Praying Mantis.
Nor a Stick Bug.
Lulu Clake (external link)
Zenfolio  (external link)
Samdiver74
Sep 03, 2007 19:50 as a reply to  @ Deckham's post |  #5
Thanks for the heads up Deckham
I knew it was a Mantis of some sort, everyone who has seen the critter over here has said it is a stick insect.
Hence the reason why I put Stick bug / Mantis, it definitely looked like part of the Mantis family.
Allan
Mrvile
Sep 03, 2007 21:44 |  #6
Great job with the eyes, they are gorgeous!
Also, just for the record, praying mantises are actually in their own order, Mantodea. Stick insects are also in their own order, Phasmatodea. Very little relation. Mantises are actually closer related to cockroaches than anything else.
Eric
Canon EF 70-300mm f/4-5.6 IS USM Review
Click-it
Sep 03, 2007 23:56 |  #7
Okay how do you get them not to move?
Canon 30D & 40D :cool:
Canon 28-135mm f/3.5-5.6 IS
Canon 85mm f/1.8 - Tokina 10-17mm fisheye lens.
Canon 70-200mm F2.8 L IS, 24-105 F4 L and 17-40mm f4 L
Canon BG-E2 Battery Grip / Canon 430 EX and 580 EX II.
Samdiver74
Sep 04, 2007 04:27 as a reply to  @ Click-it's post |  #8
Mrvile
Thanks, I love the eyes myself, I think they came out a lot better than I expected.
Thanks for the comments
Click-it
I couldn't stop him from moving, for the 5 shots I have here I probably got 40 non keepers.
I had my tripod set-up for these shots, as I was close to 5X mag.
My Delta flip flash bracket was aggravating the crap out of me, just as I would get ready to take the shot, either the Mantis would move or the bracket would let go. (wish I had the MT24EX but I don't have a way to secure it to the reversed 50mm)
it was tough even tracking the subject with the tripod, but I was able to use part of the tripod to support the weight of the Flash.
Thanks for looking and enquiring.
Allan
dreamline
Sep 04, 2007 05:59 as a reply to  @ Samdiver74's post |  #9
Very nice series. Think I'll go with pic 4 as my favourite.
Bernie (external link)
Kit list:
LordV
Sep 04, 2007 10:01 |  #10
Like #4 & #5 :)
As you know you need to control the aperture on the main lens and leave the reversed lens wide open.
Brian V.
Macro Hints and tips
Samdiver74
Sep 04, 2007 12:46 as a reply to  @ LordV's post |  #11
Thanks Brian and Bernie
I appreciate you guys taking the time to look and comment.
Brian
Yeah I definitely need to use the set-up the other way, probably get slightly better DOF control and probably a higher keeper rate.
Allan
terraform
Sep 04, 2007 17:54 |  #12
Nice! #3 composed beautifully. Without composition you have nothing. Cheers.
40D, 100mmUSM, 28-135mm USM
Mrvile
Sep 05, 2007 00:28 |  #13
Wait, so did you use flash for these shots? Because the lighting looks PERFECT.
Eric
Samdiver74
Sep 05, 2007 04:55 as a reply to  @ Mrvile's post |  #14
TerraForm
Thanks for looking and complimenting, I agree on your statement about composition, a lot of times it gets overlooked.
Eric
yeah I used flash for these, Thank you for the compliment, but thanks goes to Brian (LordV), Toby(Racketman), Mark(Bandit1), Dave(Dpastern), Artur (Zman) for the help with understanding the flash.
I usually keep the shutter speeds lower as I want to try and use flash for fill only and try and expose the background a little.
So flash and subject orientation is a big key here, the closer the subject is to it's environment the more chance you have of getting the flash to partly illuminate the background
If I used max shutter speed with the flash (1/250) then the backgrounds would usually be black.
Pic 5 is so dark in the background because the flash was directly above the subject and there was nothing directly behind,
If I remember rightly the Mantis had moved to the end of a branch in the plant it was in.
I like pic 5 as subject isolation is fairly good. Pic is somewhat Portrait-ish.
There a few hot spots noticeable on some of the other pics. They are not overwhelming though, because of the soft box diffusing the light evenly over a larger area, so there are no harsh hot spots
If you look at where the light is most prominent that is from the Flash with home made Soft box, noticeable on Pic 4 Flash was lower left.
Allan
zman
Sep 05, 2007 18:35 |  #15
WOW! Very nice series Allan. #2 & 4 are my favorites. The lighting on the fourth image looks like it's been shot by the window (without flash); I like it a lot!
3,439 views & 0 likes for this thread, 10 members have posted to it.
1654 guests, 139 members online
