Thread started 04 Sep 2007 (Tuesday) 12:20
handheld macro = VERY hard!
producerism
Sep 04, 2007 12:20 |  #1
well, at least for a beginner such as myself...
im praying for a macro IS, although not sure how feasible that would be.
my hand shake is just out of control, even with super high shutter speeds, and a wide open aperture. As soon as I see a dynatran for less than $70 I'll e grabbing it.
Until then, any tips on handheld macro shots?
30d | kitLens | sigma10-20 | canon24-105L
canon100mm USM Macro | canon50mm 1.4
producerism
Sep 04, 2007 12:21 |  #2
heres a 100% crop of the sharpest pic I've managed to capture
eccles
Sep 04, 2007 12:55 |  #3
I can't comment on your shots as I haven't the faintest idea what it is. :D
As for macro shooting tips, they're pretty much the same as normal photography: Use a shutter speed that is faster than your camera shake. To aid this:
Use a monopod or tripod.
Use a higher iso.
Use flash.
Don't shoot 1:1 macro until you've mastered lower magnifications.
Hope that helps,
Eccles.
gjl711
Sep 04, 2007 12:57 |  #4
What the heck are those?
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
illusionest
5D MkII? CHECK!
Sep 04, 2007 13:29 |  #5
hold your breath while using high magnification, it's like using a long telephoto lens, a little movement is a lot. But anyway, using a flash helps.
Matthew Law
Gallery (external link) | My Gear | IG: @matthew.law (external link)
producerism
Sep 04, 2007 13:53 |  #6
thanks, tips seem "common-sensicle,' i'll try a few new things.
i'll add that I have gotten a few sharper shots, but they were at ISO800, and in my opinion, worse than shake-blur images, because of the extreme noise.
I'll certainly try more with flash - I would like to mess with the lighting, but these are very sensitive to heat and light, so I don't want to unleash my 250 or 500w floodlights on them!
by the way: it is a mushroom colony!
I'll take some more tonight with flash, higher ISO, and i'll attempt to use my $5 tripod again as well (originally bought for a video cam, not slr).
producerism
Sep 04, 2007 13:54 |  #7
oh, and on the topic of holding breath / etc. I do that anyways - in fact, I am a marksman, and i have little to no problem with shake when dealing with guns... I didn't realize macro photography would be so much harder! ha.
Bill ­ Pham
Sep 04, 2007 15:00 as a reply to  @ producerism's post |  #8
i was gonna say looks like mushroom but you beat me to it.
Bill
winning is fun and second is for loser
I got Mitch hook on wide angle :lol::lol:
Gear list
http://billpham.smugmu​g.com/ (external link)
producerism
Sep 04, 2007 18:08 |  #9
thanks for the tips.. i added flash, raised my ISO to 400, and tried the best i could to hold my breath...
also tried taking a few steps back, and ill do 1:1 when I have a tripod that can handle it... heh.
here's a sharper photo via the suggested settings, etc.
theres still a little shake, but MUCH better.
racketman
Gallery: 20 photos
Sep 04, 2007 18:16 |  #10
that's better. No reason not to use a tripod for that sort of subject - it ain't going anywhere. Worth spending some dosh on a decent one.
Toby
producerism
Sep 04, 2007 19:07 |  #11
yup, i agree 100%
I was planning on grabbing a tripod much sooner... but these estimated payments to the IRS can do a number on my wishlist ;)
Bill ­ Pham
Sep 04, 2007 20:23 as a reply to  @ producerism's post |  #12
definately alot better with the second batch. little more practice and you get it.
Bill
Gear list
producerism
Sep 04, 2007 21:03 |  #13
thanks for the encouragement! I managed to rig my cheap tripod up so that it would hold my camera steady, even when pointing down. I kept the same camera settings as above, except that i changed the ISO back to 100, and put it on a timer, to further eliminate shake from the button press.
After browsing around for a while regarding focus stacking, I downloaded CombineZM and ran 5 shots through it, which i took in manual mode. This gave me the attached image, which I then took into photoshop for a bit of unsharp mask and level adjustment.
Unfortunately, the other stacks I've tried to process have very heavy artifacts, and a few just came out strange, nothing like a photo.
this is probably my best, and sharpest macro shot yet, so any feedback would be appreciated, in terms of what could have been done better, on any level.
here is a full-res version of the entire result:
(link) - finalstack1-copy.jpg (external link)
as far as I can tell, there are no obvious artifacts.
macro ­ junkie
Sep 05, 2007 03:51 as a reply to  @ producerism's post |  #14
looks like magic musrooms..;) great for macro work.!
Uk prayingmantis forum - http://www.dragonscres​t.co.uk/forums/index.p​hp (external link)
My flickr gallery -http://www.flickr.com/​photos/hooked_on_macro​/ (external link)
DA Gallery where i sell prints - http://macrojunkie.dev​iantart.com/ (external link)
MPE-65MM - MT-24EX Twin Macro Flash (diffused with 2 X Gary Fong Puffer diffuser)
EF-S 60mm f2.8 USM - 430ex (diffused with lumeriqest soft box)
eccles
Sep 05, 2007 04:58 |  #15
That's much better. WRT noise at iso800, I was under the impression that the Canon CMOS sensors were better than most. Perhaps you should look at noise reduction software such as Noise Ninja or Neat Image.
2,048 views & 0 likes for this thread, 9 members have posted to it.
2660 guests, 154 members online
