Thread started 05 Sep 2007 (Wednesday) 00:40
How to get rid of chrome glare?
shooterman
village idiot, actually a genius!
Sep 05, 2007 00:40 |  #1
Messed around with my flash tonight, Sunpak 433AF w/manual power adjust, shooting through a white umbrella. Couldn't get rid of the glare from the metal face plate(where it says "Princeton Reverb Amp"). I tried angling the amp, tipping it forwards and backwards slightly, moving the light around, and adjusting the flash power. Am I just an idiot or can it not be done? :o
thanks, Randy
Randy
| Canon 5D Classic | Canon 30D | Canon EF 40mm F2.8 | Canon 70-200 L F4 | Tamron XR DiII SP 17-50 F2.8 | Elinchrom D-Lites | Calumet Genesis 200 | Elinchrom EL Skyports | 27" 5K iMac |
r.morales
Sep 05, 2007 09:50 |  #2
Sometimes a UV or haze or Sky 1A . From shadow flash or light is on right so maybe a CPL .
Try a different angle move camera or subject
PacAce
Joined Feb 2003
Sep 05, 2007 10:10 |  #3
If the reflection if of the specular type, repositioning the light and/or the amp would fix that. But if the metal surface has a brushed finish to it, you may not be able to totally get rid of that reflection no matter how you position the light or the amp. In that case, a gobo placed between the light and the metal face plate should do the trick.
...Leo
canonpink
Sep 05, 2007 12:56 |  #4
Circular polarizing filters are very good with reflections. Give it a try if you have one; else, PacAce is the expert on this.
CP
No signature, but a bunch of gear.
SkipD
Joined Dec 2002
Sep 05, 2007 13:04 |  #5
canonpink wrote in post #3866851 (external link)
However.... polarized filters no not normally modify reflections from metallic surfaces in the way that they do for glass, water, etc. I wouldn't expect any advantage in this case using a polarized filter.
If you put a polarized sheet across the light and used a polarized filter on the camera's lens, there is a possiblity that you could modify the reflections a bit.
Skip Douglas
PacAce
Joined Feb 2003
Sep 05, 2007 13:07 |  #6
Polarizers are good for reflections but, unfortunately, they usually don't do much for reflections off of metals because those reflections are not polarized.
As for my being an expert, I'm actually far from being one.  :o :o
[Edit: Looks like Skip beat me to it about the polarizers. :)]
...Leo
bieber
Sep 05, 2007 13:13 |  #7
This may help:
http://strobist.blogsp​ot.com …2-specular-highlight.html (external link)
EOS 20D w/ BG-E2 grip
Nifty fifty, EF 28mm f/2.8, EF 70-200mm f/4L USM
Speedlights SB-25/SB-26/580EX, Pocket Wizards and such
My Gallery (external link)
Wilt
Sep 05, 2007 21:43 |  #8
The 'glare' of that surface is merely the reflection of the light source! If you move the light source out to the side more, or move it up high, you will not see its reflection in that surface of the amp.
Photographing glass or metal is often about putting the subject in a dark room, then placing light sources strategically so that they cast highlight at an edge rather than on a flat surface, or so that they are reflected in one surface but not another surface (e.g. faceted items)
lnterestlng
Sep 06, 2007 00:06 |  #9
pull the light down down down. I know you said you played with it but it might take more than you think. Aim the light from off to the side even with the camera height. or from directly on top. Also could try using a smaller light source.
canonpink
Sep 06, 2007 10:31 |  #10
One more thing on strobist.com.
Check this out on photographing watches.
http://strobist.blogsp​ot.com …light-to-light-watch.html (external link)
This may give a bit of insight into photographing highly reflective materials. I know that putting a gobo (piece of paper on the side of the flash to prevent spill over) can sometimes help when using multiple flashes.
Also, have you tried shooting straight down on the scene with a highly diffused flash? Seems this could get you close to what you need and prevent the reflections you want gone in the front.
CP
r.morales
Sep 06, 2007 20:55 |  #11
gobo = piece of paper on the side of the flash to prevent spill over -- should be added to the camera abbreviations . I added to mine which I stole from here .
PacAce
Joined Feb 2003
Sep 06, 2007 20:59 |  #12
r.morales wrote in post #3877411 (external link)
It's also a mask, usually black and made of some sort of board or panel, placed between a light source and the subject to prevent part of the subject or the whole subject from being directly illuminated by that light source. And it's not an abbreviation. It's a real word. :)
...Leo
r.morales
Sep 07, 2007 09:42 |  #13
Thanks I added your info to my definitions
2,390 views & 0 likes for this thread
Latest registered member is DTPhotography
754 guests, 205 members online
