That is...plugged into the wall charger even though the light is green?
Any effect on battery life if this is done?
kuma1212 Senior Member 364 posts Joined Jun 2007 Location: Chicago More info | Sep 06, 2007 10:52 | #1 That is...plugged into the wall charger even though the light is green? 5DII. 50L. 24-70LII. 16-35LII. 70-200is2.8II. 100L 135L.
canonpink Senior Member 615 posts Joined Aug 2007 More info | Sep 06, 2007 10:54 | #2 Permanent bankuma1212 wrote in post #3873908 That is...plugged into the wall charger even though the light is green? Any effect on battery life if this is done? I wouldn't. Those rechargeable lithiums don't lose juice that fast. CP
superdiver Cream of the Crop 9,862 posts Likes: 5 Joined Jan 2006 Location: Ketchikan Alaska More info | Sep 06, 2007 10:55 | #3 Once its charged its best to remove them from the power and let them sit till you use them again... 40D, davidalbertsonphotography.com
RudyM. Senior Member 489 posts Joined Feb 2007 More info | Sep 06, 2007 14:26 | #4 It is best to leave these camera batteries in a discharged state and charge before use. Don't top them off after use and recharge them every 30 days or so like NiCd or NiMH cells. Even the info that comes with the Sterlingteck battery packs states not to store them in a charged state but deplete them first. Every time you put these batteries in a charger, it is one cycle and they have a limited amount of cycles--somewhere between 200 and 300 charges. Rudy M.---Thanks to this site, I'm learning something new all the time!
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Sep 06, 2007 15:01 | #5 It's not good to let Li Ion cells go flat. It's better to keep them with some charge in them; unlike NiMH or NiCd cells they break down when drained. Jon
| Latest registered member is MWCarlsson 705 guests, 127 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
