Thread started 06 Sep 2007 (Thursday) 13:23
Newbie with a 350D any tips
Tootall180
Sep 06, 2007 13:23 |  #1
Hi guys and girls i will be getting my 350D in the post tomorrow :D so this weekend i will be going to the Duxford Airshow can anybody give me any tips or links to threads that maybe able to help me.
The 350D comes with a EF-S 18-55mm F/3.5-5.6 and EF 75-300 F/4.0-5.6 III lenses.
Many thanks.
ikolpdog
Sep 06, 2007 14:02 |  #2
Get out there, take pictures.
7D, EOS 33, Canon 70-200 f2.8 L, 24-70 f2.8 L, 180 Macro f3.5 L, EF 28 f1.8, EFS 10-22, 1.4x II Extender and 580EXII.
illusionest
5D MkII? CHECK!
Sep 06, 2007 14:14 |  #3
try 200 or 400 ISO, fast shutter ( 1/couple hundred ), and stop down a bit if you can with the 75-300. The chromatic abberations on the 75-300 is horrible, imo. Stopping down should be OK.
Matthew Law
Gallery (external link) | My Gear | IG: @matthew.law (external link)
mcmadkat
Sep 06, 2007 14:43 |  #4
For airshow stuff you will want the 75-300 mostly.
Set the focus to AI SERVO so that it will track flying planes (don't forget to go back to one shot for static display aircraft).
You are best setting the camera to Av mode and setting it to F5.6 - F8. Shutter speeds are best kept above 1/500. You may need to increase the ISO to 400 or 800 to get the fast shutter speeds.
Burst mode is useful, although you only get 6 shots in RAW, best stick to JPEG if you are filling up the buffer too quickly.
Above all, just enjoy it and don't worry too much if the pics don't all work out perfectly!
30D 17-40L 580EXII
https://photography-on-the.net/forum/showthre​ad.php?t=386249
dave ­ kadolph
"Fix the cigarette lighter"
Location: West Michigan--166.33 miles to the Cook County courthouse
Sep 06, 2007 16:08 as a reply to  @ mcmadkat's post |  #5
Go out and shoot with different settings
Keep your shutter speed up
See what works and what doesn't
Have a good time
And welcome to the forum!
Middle age is when you can finally afford the things that a young man could truly enjoy.
Tools of the trade
irish1
Sep 06, 2007 16:44 |  #6
Always, always check you WB and ISO. Play with all the settings, it costs nothing but time.
Canon 40D, Sigma 17-70, Sigma 10-20, nifty 50, 50 1.4, 85 1.8, 70-200 4L, 70-200 f/2.8 IS, 430 EX, Manfrotto monopod, tripod and ball head, Tamrac MAS system
gooble
Sep 06, 2007 17:23 |  #7
If you're shooting RAW WB can be adjusted in post so it's not critical, but can save time later on. That is if you shoot in RAW, that's your decision, I however would not consider NOT shooting RAW.
The last airshow I shot jets typically at 1/1000 or faster typically at around f/8 on AI servo, as others mentioned. I don't recall the ISOs used but probably stayed at 400 and maybe up to 800. On prop planes and helicopters you typically want to slow down your shutter to around 1/250 for planes and 1/160 for helicopters. This is so you get the blur of the props and not them frozen in air. The slower the better but at some point you'll have diminished sharpness due to your panning motion and/or movement of the subject.
Agree with those that say stick with the 75-300. I'd personally like to have a max FL of 400mm but 300mm is the longest you have and it will do well for you. Just realize that your lens is not of the highest quality so your IQ may not be the best . I'm not trying to discourage you but you should just be aware of it. If you really wanted a good airshow lens you'd have to spend around $1500 for the EF 100-400. If you have the money to burn I'd recommend you get that but if you don't just realize the $1500 lens will give you better pictures.
supergoat
Sep 06, 2007 20:43 |  #8
Take time to learn to use manual mode. It will help your pictures. I'm not saying you can't get great pics in Av to Tv mode because you definitly can, but once I learned to shoot in manual mode it's all I use now.
Canon 50D | 430exII Speedlite
Canon 50mm 1.8, Sigma 24-70 F2.8 EX HSM
gooble
Sep 06, 2007 22:31 |  #9
supergoat wrote in post #3877303 (external link)
I agree, in fact for an airshow, I'd dial in an exposure on something on the ground that is in the same light and with the same tonality as the planes and stick it in manual. This will keep the metering from being thrown off as the background changes while panning. Check a histogram every so often to check exposure and tweak as necessary.
Canon ­ Bob
Sep 07, 2007 09:05 as a reply to  @ gooble's post |  #10
I fear that the 75-300 will leave you a little disappointed with the quality of your shots. Don't be despondant by this...it's early days and you'll end up with something sharper and something that puts the colours back to what you saw through the view finder.
A UV filter would probably be useful at Duxford as the sun is never ideal from the crowdline.
Bob
1Dx2 (2), 5DSR, 1Ds3, 1D4, 5D2(590nm), 5D2(720nm) EF600 EF400 EF300-II EF300 EF200 EF200-II EF180L EF135L EF100 EF85-II EF50L TS-E17/4 TS-E24L-II TS-E45 TS-E90 MP-E65 EF70-200-II EF24-70/2.8-II EF16-35/4 EF8-15/4 EF11-24/4 Zeiss 15/2.8 21/2.8 25/2 28/2 35/1.4 35/2 50/2 85/1.4 100/2 135/2 T/C's L-SC & a WIFE!
austincabot
Sep 07, 2007 10:52 |  #11
Leave the Camera in Manual for the first month of two. It will really help you understand what's going on with the camera. You'll hate the pictures you get a first, but you'll understand a lot more than most people with a camera. It worked for me.
austincabot.com (external link) | Flickr (external link) | gear
mcmadkat
Sep 07, 2007 11:00 |  #12
I'd stick it in Av, why bother twiddling the dial and missing the shot when the camera will do it for you.
And I know what I am talking about as I have been shooting manual film cameras for years. Yes 'M' gives you control, but if you are just twiddling it until the lightmeter says is correct you are only doing what Av does.
30D 17-40L 580EXII
Tootall180
Sep 08, 2007 02:26 as a reply to  @ mcmadkat's post |  #13
Thanks for help and tips will try some out in a couple of hours, i just hope that i do not miss any planes while i am playing with different settings LOL.
chalkie
Sep 09, 2007 11:16 as a reply to  @ Tootall180's post |  #14
Well, thanks to your thread I got to Duxford yesterday; here's my best shots with the Bigma, how did you get on?
http://www.flickr.com/​gp/59824456@N00/3h8a9L (external link)
Graham
Canon 40D, Canon 350D, Canon 17-40 f4 L, Sigma 17-70 DC Macro, Sigma 18-200 DC OS, Sigma 70-300 APO DG Macro, Sigma 600mm Mirror, Sigma 10-20 EX DC HSM, Sigma 50-500mm APO DG HSM "Bigma", Kenko 2x Converter, Speedlite 580EX + Stofen, Manfrotto 680B&234RC head, Billingham Hadley Prohttp://www.flickr.com/​photos/chalkie (external link)
ikolpdog
Sep 10, 2007 15:20 as a reply to  @ chalkie's post |  #15
Tootall180 do you own a MGZT Auto? Long shot but seems to be a hell of a coincidence!
2,226 views & 0 likes for this thread, 11 members have posted to it.
2807 guests, 181 members online
