Thread started 07 Sep 2007 (Friday) 09:21
how to remove quick shoe from Markins ballhead-help please
marysia
Joined Feb 2006
Sep 07, 2007 09:21 |  #1
I could not make my mind on RRS BH40 vs. Markins M10 ballheads. Bought both to try. They are here.
M10 came with the quick shoe attached. I have to remove it to replace it with RRS clamp so I can use RRS plates.
How? How do I do it? I just do not see any obvious way of removing it.
Could somebody help, please.
m
1Dmkiii |5dii |17-40L |70-200L 2.8 IS |100-400L IS | 50 1.4| 85 1.8|100 macro | 24-105L 4 IS | 430ex | canon s90| canon g15| Man 3021BPRO+ 488RC2 I Gitzo 2540 tri with RRS BH40 ball w/ RRS clamp/plates | SLIK Sprint Mini ii with RRS BH25| SLIK SBH-100DQ| Domke F-7AF l Lowepro slingshot 200AW, 300AW I Tamrac Pro5 I Pelican Case 1450, 1510
squiress
Sep 07, 2007 10:06 |  #2
marysia wrote in post #3880701 (external link)
m
First let me say that you do not have to replace the clamp to use RSS plates. They are all (Markins, RSS, Kirk, Wimberley) based on the Arca Swiss design. Hence they will work with all the top end AS ball mounts, including the L brackets.
I don't have a Markins M-10, only the Emile Q3. On that ball mount to remove the clamp requires that you go through the bottom of the ball as it's bolted to the clamp from the underside. (That assumes a bolt and not that there is a stud on the top of the post.) If it is a stud, then you would have to lock the ball and simply twist off the clamp (which might require striking it to free it, or free whatever loctite material Markins may have used to keep it in place).
I'd give Markins a call or email them to get whatever procedure you might need to go through to remove and replace. Might be safest.
Stew
My Stuff
Thoughts-Tripods-Ballmounts-Teardown(TD)Benro KB2 Ballmount
TD Weifeng FT-565H Ballmount-TD Benro C128, C328n6 Tripods
TD Dynatran AT-A105T Tripod-TD Benro MC-68n Monopod
marysia
Joined Feb 2006
Sep 07, 2007 12:42 |  #3
squiress wrote in post #3881018 (external link)
Stew
Thank you Stew.
M10 comes with screw nob. I like RRS lever release. I like M10 but if I cannot replace this clamp, I will just have to go with BH40.
It looks to me like clamp cannot be removed from M10. It seems to be bolted on the ballhead.
I send an e-mail to Markins. No response yet. I have hard time talking to them on the phone. I cannot understand the guy who typically answers the phone.
I thought lots of people use Markins ballhead with RRS clamps and plates, Where are guys?
m
squiress
Sep 07, 2007 14:06 |  #4
marysia wrote in post #3882033 (external link)
m
JohnJ80 is the prime proponent of the RSS lever clamp here. Maybe he's on vacation.
At least you will have the opportunity to try the tension control on the BH-40. That was my only concern with this head compared to the Markins.
Stew
My Stuff
Mike ­ K
Joined Apr 2001
Sep 08, 2007 01:44 |  #5
Thank you Stew.
Simply give RRS a call during California business hours. They are very helpful over the phone. All quick release clamps are bolted/screwed onto the stem of the ball.
Mike K
Canon 6D, 1DmkII, IR modified 5DII with lots of Canon L, TSE and Zeiss ZE lenses
3,532 views & 0 likes for this thread, 3 members have posted to it.
1760 guests, 172 members online
