Thread started 08 Sep 2007 (Saturday) 11:31
real quick battery question
Redlined600
Sep 08, 2007 11:31 |  #1
Will the NB-2l battery work in a Rebel xti which came with the NB-2lh battery? whats the difference between the two? Thanks
magicmikey
Sep 08, 2007 11:39 |  #2
Yes, it will work. The NB-2LH has a higher capacity so it should last longer before needing to be charged.
Michael
JackProton
Sep 08, 2007 14:15 |  #3
Some third-party batteries are labelled as NB2L even though they have higher capacities than the NB2LH. You can consider the NB2L as the basic battery type designation in the same vein as C, D, AA, AAA, etc. The 'H' is just Canon's high capicity designation.
Cr4zYH3aD
Sep 08, 2007 16:16 |  #4
I ahve a question also:
I have two NB-2LH but i heard the new BP511 for the 40D is 1400 maH whereas H2LH are 700 maH, does it fits into the xti and is it worth it ? Looks like twice the usage
Canon EOS 7D | Canon EF 100mm f/2.8L Macro IS USM
tekkie
Sep 08, 2007 16:23 |  #5
no it will not fit the batteries are completely different
Canon 1DMKII, 7D, 5DMKII, 1D MKII
Canon 500L, 100-400L
, 70-200 2.8L, 17-40L, 24-105L, 24mm 2.8,50mm 1.4, 85mm 1.8, 135mm 2.8 SF, 100mm Macro
Canon 430 & 580 flashes
JackProton
Sep 08, 2007 17:03 |  #6
Try Sterlingtek.com for quality 1700mAH NB2L replacement batteries.
DavidW
Sep 09, 2007 12:52 |  #7
Cr4zYH3aD wrote in post #3889223 (external link)
It won't fit - BP-511 is a completely different shape. There's nothing new about BP-511 either - the 20D uses them, I believe the 10D uses them, the G6 uses them, some of the camcorders use them. Indeed, the EOS D30 (not to be confused with 30D), which was Canon's first DSLR, uses them.
David
rklepper
Dignity-Esteem-Compassion
Joined Dec 2003
Sep 09, 2007 23:21 |  #8
DavidW wrote in post #3893742 (external link)
David
I have a very old camcorder that uses them. A Canon ZR10 that was purchased in 2001. Yes it is digital. IT works fine even almost 7 years later. The reason not to update is the use of the BP511's, then I can just have one type of battery.
Doc Klepper in the USA
I
1,339 views & 0 likes for this thread, 7 members have posted to it.
2138 guests, 127 members online
