Thread started 09 Sep 2007 (Sunday) 14:41
Unusual happening with 40d today
Gliderparentntn
Sep 09, 2007 14:41 |  #1
While out shooting pictures of a Green Heron this morning I noticed that while I had the camera in the info mode and touched the shutter button my shutter speed would read something like 1/1600 and a friend next to me camera was showing like 1/60 and we couldn't figure out what was happening why I was showing this unusual high shutter speed over his body. Then we put our hand over the eye piece and pressed the shutter button and the shutter speed then dropped down to 1/60 sec also.
Now why would the sensor be picking up light thru the eye piece?
I like to add his body would not show this type of shutter speed while the eye piece wasn't covered like mine was.
James
1DMKIII, 1DsMKIII, 17-40L, 24-70L[COLOR=black], 135[COLOR=red]L, 70-200 f/2.8L IS,200L, 300 f/4L IS, 400 5.6L, 600L, 85 f/1.8, 100 macro, Sigma 50mm f/1.4 HSM, Sigma 85mm 1.4 HSM, 1.4xII + extension tubes, MPe65
JeffreyG
Gallery: 42 photos
Sep 09, 2007 14:43 |  #2
Because the meter is in the pentaprism and can see back through the viewfinder. This is why Canon gave you that little rubber bit to cover the viewfinder in you box. You are supposed to put that on for shots that you meter when your eye is not pressed to the viewfinder....like on a tripod.
cosworth
I'm comfortable with my masculinity
Sep 09, 2007 14:44 |  #3
If the sun had been shining RIGHT in it possibly.
1 series bodies have a shutter on the eyepiece for bulb exposures etc. Light can enter there.
That's all I got.
people will always try to stop you doing the right thing if it is unconventional
Full frame and some primes.
FREEZE
Sep 09, 2007 14:44 |  #4
Isn't that supposed to be that way on the rebel xt they provide a little rubber cap to cover the eyepiece for when you are doing timershots where your eye is not at the camera.
edit oops you guys beat me to the punch:o
Freeze:cool:
Gliderparentntn
Sep 09, 2007 14:46 |  #5
JeffreyG wrote in post #3894293 (external link)
I got short changed as I don't see no cover for my eye piece in my box. :confused:
James
farrukh
Sep 09, 2007 14:47 |  #6
May be you pressed the * button by mistake that locked the exposure while you were pointing at the sky or bright subject.
5D Mark II + 40D | Lenses: Sigma 150-500mm BigmOS / Canon 24-105mm F4L IS / Canon 70-200 F4L IS / Canon 85mm 1.8 / Sigma Macro 70mm f/2.8 EX / Sigma 10-20mm EX / Canon 50mm f/1.8 II / Sigma 1.4x APO TC / Kenko 2x PRO300 DG. Lighting: Canon 580EX II + Metz 58 AF-1 + Sunpak 383...
John_B
Gallery: 178 photos
Sep 09, 2007 14:49 |  #7
Gliderparentntn,
It can and sometimes has happened on all my Canon DSLR's. The eye piece cover is attached to the Canon strap that comes with your camera. It looks like a little rubber rectangle.
click to see (external link)
Nick_C
Sep 09, 2007 14:49 |  #8
I never use the rubber cover unless its night shots, never had a problem in daylight even with the sun from behind, if your on a tripod & suspect this then a hand over the eyepiece is usually enough, ive certainly never seen this effect the shutter speed as much as you saw, might have been something else?
John_B
Gallery: 178 photos
Sep 09, 2007 14:55 |  #9
Nick_C,
Well it happens, try going into a dark room and take the meter reading set your aperture and shutter and then shine a flash light into the eye piece and you will see the meter bounce all the way to the right. Now imagine what sunlight can do...
Yes it even happens on a 5D :lol:
Nick_C
Sep 09, 2007 14:58 |  #10
John_B wrote in post #3894359 (external link)
Nick_C,
Yes I know, I didnt say it doesnt happen, ive seen it, but I cant say that ive ever had it effect the shutter speed as much as the OP saw, 1/60th or 1/1600th ?? but maybe light levels are brighter over there or it was an extreme case, or maybe he just had a specular highlight in his shot from something nearby which fooled the metering ;)
xarqi
Sep 09, 2007 15:04 |  #11
Gliderparentntn wrote in post #3894308 (external link)
It's on the strap of my 30D; not sure about the 400D though.
morehtml
Sep 09, 2007 15:06 |  #12
You need to be looking through the viewfinder so light doesn't enter and throw meter off. 30d had a rubber piece that would slide on strap that could cover viewfinder if you want or just hold hand over it.
"Allen's Visions of Nature Gallery" (external link)
www.allensvisions.com (external link)
more glass than I need
Gliderparentntn
Sep 09, 2007 15:07 |  #13
We were side by side pointing at the same Heron, I'm unsure if he had his Mk 1 at the time or his D 60 mounted up when we were comparing. Anyhow thanks for the input I thought maybe something was wrong where mine was showing this and his wasn't.
James
Bill ­ Boehme
Enjoy being spanked
Gallery: 39 photos
Sep 09, 2007 15:15 as a reply to  @ Nick_C's post |  #14
cosworth wrote in post #3894297 (external link)
No, if that that much light entered through the viewfinder, it would probably result in the image being almost completely dark. My experience is that the image will be underexposed for any type of outdoor lighting conditions if I do not cover the viewfinder when using a tripod.
It is NOT in the box (at least not anymore) -- it comes already threaded onto the neck strap. For some unknown reason they install it upside down and on the wrong strap (as far as my preferences are concerned, but they forgot to consult me about it). :rolleyes:
Atmospheric haze in images? Click for Tutorial to Reduce Atmospheric Haze with Photoshop.
Gear List .... Gallery: Woodturner Bill (external link)
Donate to Support POTN Operating Costs
scrumpy
Joined Jun 2004
Sep 09, 2007 15:19 |  #15
First I have heard about this problem. On a tripod I often stand back and release the shutter :lol:
It's no wonder I take a lot of crxxp pictures :rolleyes:
David: Canon EOS 400D - Canon EF70-300mm f/4-55.6 IS USM -Sigma 17-70 F2.8-4.5 DC Macro - Sigma 50-500 'Bigma' - Speedlite 580EX 11 - Better Beamer
Have patience. All things are difficult before they become easy ;)
5,012 views & 0 likes for this thread, 26 members have posted to it.
2771 guests, 179 members online
