Please give me some advice on a problem with my camera. I’ve had this Canon SD400 for maybe about 2 years, and now it won’t work. It remains with the lens extended even though it is turned off. I bought new batteries and charged them, but the symptoms remain the same. If you try to turn the camera on, it makes a whirring sound, the lens retracts and then immediately extends again, and then the camera turns off, even though the lens is still extended. Has anyone heard of something like this before? The camera can’t be used at all.
Also I wonder if I could have a bad charger. When I put the battery in the charger, it shows amber, like it should. But then it shows green in about 10 minutes. That does not seem like enough time to charge the battery. But would a failed or dead batter make the camera leave fail and leave the lens extended?
PowerShot SD400
Digital ELPH
Ai Af
On bottom:
PC1150
DC 4.3 V
No 0723330709
