I just took a few pictures with the two bodies. Nothing high-tech here.
A single light fixture, above and to the left of the frame.
70-200 2.8L IS on a tripod with the IS disabled. Roughly 110mm for the 40D, 173mm for the 5D.
Shots taken using the timer.
Camera set in Av mode.
No control modifications
AWB.
5D set to Faithful, 40D set to Neutral (remebered after the fact)
The 5D was also set for center point focus (didn't realize until I looked at the focus points).
Shots taken at 100, 400, 800, 1600, and 3200
There are 9 images in the directory, 4 from the 40D, 5 from the 5D. (Forgot to turn ISO expansion on on the 40D) These are the CR2 files. They can all be opened in ZoomBrowserEX 5.8.
As you can tell from my sig, I either have no horse in this race or a lot of ponies, depnding upon your point of view
The files can be downloaded from http://www.chernicoff.com/pictures/ISOTest/![]()
Draw your own conclusions and post here, if you download the files; it's clearly marked in the file names as to what they are...
Now that I'm looking at he images I realize that the focus point issue does have a significant impact on the results. I might have to redo this later tonight.
