Thread started 10 Sep 2007 (Monday) 16:07
Need help assigning buttons on my 40D
Ben ­ Daniels
Sep 10, 2007 16:07 |  #1
Hi all,
I need some help please as I am stuck as to how to set the buttons on my new 40D to the way I used to have them on my D60.
Someone set the D60 for me years ago, and I never once changed them, and now I am baffled as to how to set up the 40D in the same way.
This is the way I have my D60 buttons set.
Looking through the viewfinder I push the * button which sets the focus point and I then take the photo.(How do I set this with the 40D?)
The next thing I cant sort out is:-
On the D60 to set the over or under exposure, I push the shutter down halfway and use the main wheel at the back, and turn either clockwise for over exposure, or counter clockwise for under exposure.(How do I set this on the 40D?).
I hope that my questions can be understood!
Many thanks for any help. ;)
Ben
5DMK2 w/Grip: 40D w/Grip: Canon D60: 100mm F2.8 Macro USM : EF17-35mm F2.8
L : EF70-200mm f4L IS : Canon 1.4x Converter II : BG-E2 grip :TC420EX : Tamrac Ex5 bag :Manfrotto 055XPROB:Lee Filter System
Ben ­ Daniels
Sep 11, 2007 01:46 |  #2
Bump...
Anyone?
f50fan
Sep 11, 2007 02:04 |  #3
dont mean to be cocky or anything but have you tried reading the manual? im sure that it would help you with your second problem, as its a basic function. not sure about the first though, as i dont understand what you mean fully. so i cant suggest anything.
Mark0159
I say stupid things all the time
Gallery: 45 photos
Joined Mar 2003
Sep 11, 2007 02:06 |  #4
I had the same setup on the 10D. You now have to use the AF-On button at the back of the camera.
change C. FnIV to option 2 Metering Start/Meter+AF start this will give you what you need
Mark
https://www.flickr.com​/photos/52782633@N04 (external link)
Canon EOS 6D | Canon EF 24-105mm f/4L IS USM, EF 17-40mm f/4L USM, EF 50mm f/1.4 USM, EF 100mm f/2.8 Macro USM | Tamron SP 35mm F1.8 Di VC USD | Canon Speedlite 550EX -|- Film | Canon EOS 3 | Olympus OM2 | Zuiko 35mm f2
Ben ­ Daniels
Sep 11, 2007 02:09 |  #5
I have looked at the manual, but didnt fully understand it, hence my question here.
Thanks flyingkiwi, I will give that a try.
gooble
Sep 11, 2007 02:15 |  #6
Your second question seems to be regarding exposure compensation(EC). While in Av, or Tv mode you adjust EC with the quick control dial on the back. It's the bigges thumb wheel. Hope that helps.
sbressler
Sep 11, 2007 02:20 as a reply to  @ gooble's post |  #7
In order to do this, make sure the power switch is pushed all the way to the top. The middle, on setting will not allow this functionality.
FOR SALE/TRADE: Canon EF 28-70 f/2.8L | Looking for a 1D Mark III? Look here!
Gear: Canon EOS 1D Mark III | Canon EOS 400D (XTi) | 35mm f/1.4L | 28-70mm 2.8L | 70-200mm 2.8L | 580EX II
Mark0159
Gallery: 45 photos
Joined Mar 2003
Sep 11, 2007 04:06 |  #8
Ben Daniels wrote in post #3905453 (external link)
well let us know if you have any other problems. Those options are the ones you can use to change the way you AF and which buttons you can use. I would recommend that you select each one and see what the camera does.
this is the best way of know what each option does. But yes the manual isn't that useful.
that's why we are here :)
Mark
1,897 views & 0 likes for this thread, 5 members have posted to it.
861 guests, 133 members online
