Thread started 11 Sep 2007 (Tuesday) 06:13
Best route for me to get into macro?gear wise...
Tobiah
Sep 11, 2007 06:13 |  #1
Tubes or a new lens? which lens would you recommend ?
currently have
canon 70 200mm L 2.8 IS
canon 50mm 1.8
tamron 70 300mmm macro (not up to job can't focus close enough)
canon 18 55kit lens..
was looking at a tamron 105 f2.8 macro will that get me close for really good macros like I see here... not bothere about 1 ;1 may even want to magnify....
I'm quite the photography newb but all info is welcome thanks!
[URL="http://[URL]www.​tobiahtayo.com/"][SIZE​=2][COLOR=darkorange] [Blog] Various canon gear....
John_B
Gallery: 178 photos
Sep 11, 2007 06:19 |  #2
Tobiah,
I recommend the Canon 100mm f/2.8 macro lens.
If money is tight then I recommend the Kenko extension tubes. If money isn't tight then best is both, Canon 100mm f/2.8 and a set of Kenko extension tubes and a flash & tripod.
click to see (external link)
LordV
Sep 11, 2007 07:12 |  #3
If you are serious about getting into macro then a macro lens around 100mm is a great place to start (Tamron 90, sigma 105, canon 100) are all optically excellent. If you are not certain yet then a set of extension tubes (Kenko) on your 50mm or 70-200mm lens will do the trick. You'll get just over 1:1 magnification with the 50mm lens although the focus point will be fairly close to the lens (about 2" in front).
Brian V.
Macro Hints and tips
macro ­ junkie
Sep 11, 2007 07:18 as a reply to  @ LordV's post |  #4
if your seroius and have the money u need mpe-65..be warned tho the lens only does 1:1 and behond.or set of kenko tubes with 100mm macro lens do u good..:)
Uk prayingmantis forum - http://www.dragonscres​t.co.uk/forums/index.p​hp (external link)
My flickr gallery -http://www.flickr.com/​photos/hooked_on_macro​/ (external link)
DA Gallery where i sell prints - http://macrojunkie.dev​iantart.com/ (external link)
MPE-65MM - MT-24EX Twin Macro Flash (diffused with 2 X Gary Fong Puffer diffuser)
EF-S 60mm f2.8 USM - 430ex (diffused with lumeriqest soft box)
MacroJunkeh
Sep 11, 2007 10:50 as a reply to  @ macro junkie's post |  #5
junkie what lens are you referring to when you say it does only 1:1?? the mp-e65mm?
racketman
Gallery: 20 photos
Sep 11, 2007 10:52 |  #6
MacroJunkeh wrote in post #3907444 (external link)
he means it doesnt do LESS than 1:1 ie it does from 1:1 TO 5:1
Toby
MacroJunkeh
Sep 11, 2007 11:09 as a reply to  @ racketman's post |  #7
thanks racketman forgot about looking at it from that perspective. but makes sense
Wekkel
Sep 11, 2007 13:41 |  #8
I recently got tubes for a nickle and a dime.
Yes, I lost electronic contact between camera and lens.
Yes, the extreme tube length is worthless due to an ultrathin DOF
Yes, I have fun for less than 10 euros :D
I can always purchase real gear at a later moment.
Bootsie
"Dang! I am a loser"
Sep 11, 2007 14:58 |  #9
I am going to get a Canon 100mm, and a 430ex flash to get started. I have read that this lens is great for portraiture along with macro, so I am hoping that I will get lots of use out of it. If I really enjoy the macro stuff I will get a set of Kenko tubes in a few months, but I think this is a good start.
Every review that I have read about the 100mm has been very very good, so I hope that my experience with it is good.
{Brooke}
Canon 50D Gripped| 85 1.8| 100 2.8 macro| 17-85 IS| 50 1.8| 70-200 F4 L IS!!
---My Gallery--- (external link) ~My Blog~ (external link) **All My Gear**
eccles
Sep 11, 2007 16:07 |  #10
Wekkel's got a point - try before you buy. I took lots of semi-macro pictures with a Canon compact and a 500D c/u lens and have had several of them published in local nature magazines. Most of them were also well received here. I have recently got a Sigma 105 macro and it's more difficult to get decent pictures from it compared to the compact + c/u lens. But you're right, 100mm macros are useful for general photos as well as close ups.
dpastern
Sep 11, 2007 20:53 |  #11
My take on this - grab a set of Kenko tubes and have some fun. Use the 50mm f1.8, and you'll get 1.4:1 (ie. 1.4x life size). The problem with this combo will be working distance, and it almost certainly necessitates the usage of flash and a flash bracket, along with an offshoe adaptor, adding to the cost. Bonus? You'd really need the flash bracket and offshoe adaptor anyways even if you buy a dedicated macro lens.
If you like macro shooting, you can then keep the tubes and invest in a dedicated macro lens and even combine the tubes and macro lens for higher magnification shots. I would strongly suggest that you NOT consider the MPE-65, at least until you've dipped your feet in the pond and have gotten used to macro shooting, etc.
Just my honest advice.
Dave
1,429 views & 0 likes for this thread, 10 members have posted to it.
2712 guests, 154 members online
