Tried to get the softened effect on the water.
The leaves are a little over-exposed IMO. Can some PP be applied in that area alone? Would I have to do some masking in PS?
Feedback appreciated
rs666 Member 104 posts Joined May 2006 Location: United Kingdom More info | Sep 11, 2007 08:28 | #1 Tried to get the softened effect on the water. The leaves are a little over-exposed IMO. Can some PP be applied in that area alone? Would I have to do some masking in PS? Feedback appreciated ![]() 30D....all the gear....and no idea!
babyduckmonger Member 172 posts Joined Aug 2007 Location: Memphis, TN More info | Sep 11, 2007 09:34 | #2 The easiest (but not necessarily nicest-looking) solution would be to simply use the burn took on the overexposed parts of the picture. To be safe, I would make a duplicate layer of the picture and do the burning on that layer. It won't do the absolute best job of keeping things looking natural, but if you're subtle it shouldn't stand out too much. My 2 second attempt at burning the image tells me that you have not lost the information on the leaves, so they can be toned down.
If you have ACR, I would decrease exposure a bit, then add some fill light. If you go overboard the image will turn flat on you. The things you do for yourself die with you, the things you do for others live forever.
| Latest registered member is SteveeY 1685 guests, 172 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
