Thread started 11 Sep 2007 (Tuesday) 09:23
Shooting lightning
ps249
Sep 11, 2007 09:23 |  #1
Here is a pretty neat guide for shooting lightning that I cut and pasted from another website. Looks to be very informative:
"first........make sure you have a tripod. secondly, you won't have much luck during the day, so make sure you go out after it's completely dark. I've not ever had much luck with any daylight out. Find a "safe" spot to shoot (there may not be many so be careful...this can be quite dangerous!) and set up before the storm hits so you're not out in the rain (may want to take an umbrella). I prefer to take someone with me just in case something happens. Just as a reminder, you do NOT want to stand out after it's raining as you will get water everywhere on the camera...even with an umbrella, and again, please be careful as this can be very dangerous. Don't stand outside if the storm gets too close. My wife knows a guy who did get hit by lightning a few years ago and he did recover, but he has tons of problems with motor skills, and other problems as well.
As far as camera settings, you will want to use "manual" mode and probably set your shutter speed to "bulb", aperture to f 10 or so, and use ISO 200 (that's what I usually do). You can always experiment with this. You also may want to invest in a remote release for the 20d, I have one and it's 10 times better than pressing the button and holding it down on the camera. You can't use autofocus, turn it to manual and focus just shy of infinity. I zoom all the way out, you may want to use somewhat of a wide angle lens. Aim where you think the storm is coming from and depress the shutter button (or the release cable) and hold it down. Wait until lightning hits and then you can let go. That will expose the shot. The lightning will have plenty of light, it's almost like daylight out if it's close enough. Also, if you have the noise reduction turned on in the camera settings it basically takes double the time to take the picture (i.e. if you expose the shot for 45 seconds, it will take another 45 seconds or so for the camera to process the file and reduce the noise. During this time you won't be able to take another picture) Anyway, the actual pictures will be dependent on obviously where the lightning is hitting (It gets depressing when you have your camera shutter open and the lightning hits just off to one side of the frame!). Overall just be patient and try to take your time in trying to find a good spot and BE SAFE!"
40D
50 f/1.8 | 28-135 IS |
MAUREEN SOUZA FOR PRESIDENT!
I ­ Simonius
Weather Sealed Photographer
Gallery: 19 photos
Location: On a Small Blue Planet with Small Blue People With Small Blue Eyes
Sep 11, 2007 09:37 |  #2
I have often wondered about the way to expose for lightning but even though i got some good shots waaaay back in the past I can't rmeember how
Will have to give it anotheer go wiothout becoming a ';stormchaser'
;):D
Veni, Vidi, Snappi
Website  (external link) My Gear ---- (external link)
mcmadkat
Sep 11, 2007 10:06 |  #3
For daylight shooting get a strong ND filter.
Or just put it on burst mode and fire away! I took 800+ shots without stopping (small JPEG) and got this in the day time:
30D 17-40L 580EXII
https://photography-on-the.net/forum/showthre​ad.php?t=386249
shooter76
Joined Jul 2004
Sep 11, 2007 16:53 |  #4
mcmadkat wrote in post #3907199 (external link)
so what was the keeper rate.....1 out of 800!! :)
mcmadkat
Sep 11, 2007 17:05 |  #5
Yup, or 0.00125%
30D 17-40L 580EXII
JimMcrae
Sep 11, 2007 17:10 |  #6
Was that with the Sigma 30mm or 50mm? ;)
60d, 400d, 100-400mm f/4.5-5.6, 24-105mm f/4, 50mm f/1.4, 580ex II, 2 X 430ex II, Bowens 500, cs5
EOS20DAUS
Sep 11, 2007 17:56 |  #7
I Usually set my camera on BULB and an ISO of around 50 to 100.
As for appeture F/8 to F16 seems to work well depending on where you are shooting and if there are street lights around.
As for what to use, Get a very sturdy Tripod and a remote release for your camera, I currently use the Canon TC-80N3 remote timer for my shots.
I also use my 50/1.4 for most of my shots but I am saving up for a 12-24 Sigma to take in more of the sky.
Then every now and then you get a shot like this:D:D:D
IMAGE: http://i76.photobucket.com/albums/j16/Eos30Daus/IMG_4428.jpg
Canon Eos 1D Mark II N | Canon Eos 30D + grip | 50 f/1.4 | 28-135IS | 70-200 f/2.8 L.
I have a terrible case of the L's
tomdlgns
Sep 14, 2007 08:49 |  #8
nice...that is the type of shot i want to get. i am sure i will take thousands of pictures before i figure out what the hell i am doing.
none
LotsToLearn
Sep 14, 2007 08:57 |  #9
There's also a trigger you can buy that helps take the guess work out of it.
Lightning Trigger (external link)
There was also a good article in Outdoor Photographer a month or two ago that you can probably still find online that had alot of tips.
tomdlgns
Sep 14, 2007 11:01 |  #10
nice i will look into that.
none
Sgt_Hovanec
Sep 14, 2007 11:23 as a reply to  @ tomdlgns's post |  #11
The lightning trigger is OK for camera's that have a shutter lag shorter than 50ms. Otherwise it doesn't help. I haven't tried it yet. I have been shooting lightning for about 18 months and have an extensive collection. The pictures isn't what makes it difficult. It's the chasing and framing. You also need to be available at all times for the storms. My files are too big for this site but if you are interested you can take a look here:
http://www.wundergroun​d.com …nec&handlebox=1​&submit=go (external link)
Here is the basic way of shooting:
http://www.wvlightning​.com/ptips.shtml (external link)
Then you need to teach yourself based on your gear, location, and shooting styles.
My Gear List - Lightning Photography Extremist
Sgt_Hovanec
Sep 14, 2007 11:28 as a reply to  @ Sgt_Hovanec's post |  #12
A quick daytime shot.
tomdlgns
Sep 14, 2007 11:28 |  #13
there are some awesome shots in there.
none
1,801 views & 0 likes for this thread, 9 members have posted to it.
Shooting lightning
2807 guests, 181 members online
