Thread started 11 Sep 2007 (Tuesday) 18:13
eos 20d action settings
markham
Sep 11, 2007 18:13 |  #1
hello I am new here and this is my first post . I apologize if this topic has been up before , but I couldnt find it . I have had my canon eos 20d for a few months . I am having trouble with motorsports action shots , mostly monster trucks. I am using the ef-s18-55mm f/3.5-5.6 lens , shutter 1/50 focal lenght 55mm , f/5.6 , iso 200 . most of the shots are blurred , on others the body of the truck is in focus but the tires and background are not . I have tried panning with the truck and a few other things but seem to always get the same result . I tried to post a pic to show you an example , but I am not sure it worked ? Any tips or help you could give would be greatly appreciated . thank you
DDan
Sep 11, 2007 18:25 |  #2
Welcome to the board Markham. You need a little faster shutter speed. 1/100 will work better. Closing the aperture down to f/8 will sharpen the picture up a bit as well. To get these settings to work you are going to have to turn the ISO up a notch or two.
DansRacePhotos.com (external link)
Dangerous Dan
markham
Sep 12, 2007 11:41 as a reply to  @ DDan's post |  #3
Thanks for the help ! Maybe an iso of 400 would be better ? Do you know of a good book or dvd available that might help me with some of these questions ? thanks again
DDan
Sep 12, 2007 11:47 as a reply to  @ markham's post |  #4
The good advice over in the motorsports forum is free. :D
Dangerous Dan
Mark_Cohran
Joined Jul 2002
Sep 12, 2007 12:06 |  #5
You need to study up on Depth of Field and Motion Blur - these are the two factors that are impacting your photographs the most. DDan's advice is good - but you also need to understand why it's good. :)
Mark
Mark
Some primes, some zooms, some Ls, some bodies and they all play nice together.
Forty years of shooting and still learning.
My Twitter (external link) (NSFW)
Follow Me on Instagram (external link)
Seefutlung
Joined Feb 2006
Sep 12, 2007 12:50 |  #6
For action/sports type shots typically you want to isolate the subject from the background. This means longer focal length lens with larger apertures. As a general rule shoot sports like the big boys (news photogs), wide open. At 55mm wide open is 5.6 ... which is still way too much DOF for a "great" shot .. but the best you can do using the equipment you have.
1/100 is also way slow of a shutter speed ... I think the minimum shutter speed for fast moving trucks will be at least 1/250 to 1/500. To attain that speed you'll probably need ISO 1600.
I suggest this methodology-
You need to shoot in manual or AV. Let's just talk manual ... set your shutter to 1/250 and your aperture to wide open (extend your zoom to 55mm then open it up). Then adjust your ISO until your meter is centered. Shoot a couple of test shots, check your histogram, enlarge an image on the LCD and look for sharpness. If the image is still blurry (as opposed to OOF), then do the above again this time with the shutter at 1/500.
I shoot a lot of sports. Remember the higher the ISO the more noise (grain) you will have. Many post processing programs will have noise reduction capabilities and there are programs which all they do is noise reduction. I strongly recommend shooting in RAW for easier color correction.
There are many ways to attain proper metering ... I just suggest one method.
Gary
PS- Not a bad pan though.
G
- Unsharp At Any Speed -
LAShooters (external link) for SoCal shooting
www.garyayala.smugmug.​com (external link)
runninmann
what the heck do I know?
Gallery: 47 photos
Joined Feb 2006
Sep 12, 2007 15:26 |  #7
I think that's pretty good considering the lens and shutter speeds. Please be aware that the tires are probably rotating faster than the truck is moving, so even with perfect panning, they will probably be blurred. The blurred background and wheels/tires help impart a sense of motion to the shot.
1,768 views & 0 likes for this thread, 5 members have posted to it.
2878 guests, 176 members online
