When I first discovered this feature I thought it was great. I set it up so that it will activate mirror lock-up and the self timer. This way I can shoot landscapes and select these settings without having to go through the menus.
The only downside is: each time the camera is powered off, or it goes into sleep mode, the aperture and S/S return to their default values at the time the settings were registered (1/250's f/16).
Is there a solution to this? It becomes a bit of a pain if you're waiting for the right moment and you go to shoot, only to find the exposure is way off because the S/S or Av have changed.
