Ok, I was fortunate enough to have a co-worker let me borrow his wife's week-old 40D for a night, which I took the opportunity to collect thoughts on it and compare it versus my 30D for what I'm specifically looking for: in a camera- ISO performance. My humble "review" is as follows:
40D Initial impressions:
PROS:
- The camera is slightly larger than my 30D and fits a little more comfortably/ergonomically in my hands which is nice.
- The 3" LCD was also a nice addition and plus for the camera, its also a bit brighter than my 30D's.
- The settings wheel on the top is also a little larger in diameter which is nice. - The view finder is also a little bit larger which makes composition a bit easier as well compared to my 30D.
- The constant ISO display I think, of any of these PROS IMO is the biggest plus for the non-performance aspects the camera offers.
- The shutter speed is also quieter as has been reported, and its not quite as silent as the 5D, but is noticeably not as loud as the 30D.
CONS:
- I did not like the button layout on the back of the camera at all, I more than once during my brief time using it made contact with the buttons and once actually hit the play button.
- I didn't like the split rubber seal that encloses the remote shutter port, USB port, etc, I liked the 30D's design a little bit better.
- Canon did nothing to enlarge the little tiny joystick button above the scroll wheen on the rear of the camera. Given that this "joystick" is used more now for navigating through the menus, I thought it would've had some enhancements ergonomically to it, I find it small and dinky.
- With the larger LCD, I'd be curious to see a scientific study as to battery life to see if the battery drains any faster with that monster LCD.
FYI'S:
- I did not have enough time with the camera to explore the Live View mode and can't comment on it.
- I didn't get home until late, consequently I did not evaluate its autofocus capability which might entice some folks to be attracted to the camera. Again, my main focus with the limited time I had it was "is the ISO performance improved, equal to, or inferior to the 30D?" Given that I am getting into wedding photography and looking to grab a 5D soon, ISO performance is important to me.
ISO Test Setup:
Both cameras were mounted on my Manfrotto 3021 tripod and the shutter was actuated with my Canon RS-80N3 remote switch. The lens used for both cameras was my 24-70 f/2.8L at an aperture of 2.8. I locked the focus point to the center point on both cameras and left the white balance to "Auto". The ISO for all the images taken for both cameras was constant at 1600. All closeups were shot at 70mm and the room shot was at 24mm (not factoring in the 1.6CF). I aimed to emphasize all my shooting under low-lighting conditions, as I've seen some people try to evalute the 40D's ISO performance under bright lighting, or even outdoors which isn't the environment I typically need to boost my ISO nor will you see much noise (those shooting high-speed motorsports I'm sure may need to boost it, but again this study was aimed specifically at indoor, low-lighting). All images were shot in JPEG high-quality (large). (Note: I originally shot both in RAW, but was unable to read the 40D's RAW images as I didn't have the software that came with the camera, consequently I had to go back and reshoot everything on both cameras in the highest quality JPEG setting and compare). When shooting the images, the meter reading for each compared image were identical (i.e. the close-up of the vase was the same for the 30D and 40D).
Results:
All the images taken, including the 100% crops can be viewed and downloaded from my new flickr site at:
http://www.flickr.com/photos/83757848@N00/![]()
I encourage anyone interested to go in and download any of the images they would like to compare side-by-side for themselves. Please note I seperated the two sets into a "40D" and "30D" folder.
I noticed the color tones were slightly different from the 30D vs 40D which led me to verify the white balance on both of the cameras were identical and set to AWB. BOTTOM LINE: I FOUND THE ISO PERFORMANCE OF THE 40d TO BE NO BETTER THAN THAT ON THE 30d. I DO NOT BELIEVE THE NOISE LEVELS ON EITHER CAMERA CAN EVEN BE CONSIDERED ON PAR WITH THE 5D AT IDENTICAL SETTINGS. It actually looks like Canon incorporated more in-camera noise processing to get the noise levels even close to the 30D. This was what I suspected given that Canon crammed small photocells onto the same sized sensor. For those 5D owners out there, you can breath easy as I still say the 5D, outside of maybe the 1D's, the ISO king and is a step above the XXD series.
CONCLUSIONS:
As I did this study, I had to ask myself as a current 30D owner, "would I want to buy this camera and dump my 30D?". Based upon what I evaluated, I would have to say NO* with an asterisk. Given that I didn't evaluate the susposed improved autofocus, that might sway some folks. I for one think the 30D's autofocus system has more than suited my personal needs, however depending on your shooting style and opinion, it may justify the switch. I don't feel that the $300.00 premium Canon is asking for this camera is worth it. Don't get me wrong, it is a fantastic camera. However, I really feel Canon should've and could've pushed the envelop further (ala Nikon), especially given that they didnt do much from the 20D->30D. I would've liked to have seen a higher fps improvement for one (something along the lines of 8fps, nothing to infringe on the Mk3, but more is needed to differentiate its frames per second from the 30D and I don't think 1.5 frames more is enough). I also would've liked to have seen improved noise control at higher ISOs. The resolution upgrade doesn't do much for me as I don't really blow up poster sized prints so it does nothing more than fill my cards up quicker with larger files. My note to others would be that you shouldn't expect any improvement in terms of noise with this 40D compared to the 30D. Again, there may be other reasons you personally may find justify the premium, I for one do not, and will be happily content to keeping my 30D.
If anyone has trouble downloading please let me know as this is my first time using Flickr.
Now... I'm going to go cook some popcorn, and sit back for the flames......
I'm sure I'll adjust but I'm unhappy right now. Especially with the lack of erase all from the preview - maybe I just haven't found it yet. But it's a missed choice I loved on my 30D for some reason.
