Thread started 14 Sep 2007 (Friday) 01:17
is it the 40d or is it LR?
azpix
Sep 14, 2007 01:17 |  #1
Took a few B & W with the 40d, now in LR they are color? why is that?
Does the 40 record the image in color and convert on the camera? or is LR converting the B & W to color (if that's even possible?)
Gear- 7d, 24-70L, sigma 70-200, Sigma 120-400, canon 50 1.4, Canon 100 2.0,sigma 10-20 and a DJI Mavic Pro Drone
Nzshrimper
a good height for ...
Sep 14, 2007 01:22 |  #2
well i would say its te camera recording the data with colour- are you shooting raw or jpeg.
© All rights given away
Grammar – the difference between knowing you’re sh1te and knowing your sh1te
Mark0159
I say stupid things all the time
Gallery: 45 photos
Joined Mar 2003
Sep 14, 2007 01:42 |  #3
what format are you shooting in, RAW or jpg.
the camera handles these 2 types of formats completely differently
EDIT: I don't use LR but I do use Photoshop and adobe bridge. This will be using the same RAW converter as LR. It would seem that the RAW converter ignores the B&W data attached to the RAW file. I shot an image in B&W and in RAW and then opened it in Photoshop and it opened it in colour.
Now I have no idea if this is a function of the converter or if Adobe is missing something.
JPG is fine, shot in B&W and it displays it in B&W
Mark
https://www.flickr.com​/photos/52782633@N04 (external link)
Canon EOS 6D | Canon EF 24-105mm f/4L IS USM, EF 17-40mm f/4L USM, EF 50mm f/1.4 USM, EF 100mm f/2.8 Macro USM | Tamron SP 35mm F1.8 Di VC USD | Canon Speedlite 550EX -|- Film | Canon EOS 3 | Olympus OM2 | Zuiko 35mm f2
tzalman
Fatal attraction.
Sep 14, 2007 02:32 |  #4
Every image recorded by the camera is first of all a RAW data file. If you wish the camera will then use that data to construct a jpg. At this time parameters like sharpness and Picture Style are applied, including b/w. If you choose not to make a jpg but rather export the RAW data file, those parameters are noted in the metadata section of the file. Canon software can read all the metadata and will use it for setting defaults. Third party converters can read only part of the metadata, usually only WB and basic Exif camera parameters like ISO, f/stop, speed, etc. They will use their own generic defaults but then the rest is up to you.
Elie / אלי
gooble
Sep 14, 2007 02:44 |  #5
Most likely you are shooting in RAW with the B&W set and LR does not see the B&W tag or metadata and displays that image as color. If you opened it in DPP it would show up as B&W, but then you could go set it back to color if you wished.
If you shot a jpeg set to B&W there'd be no way to make it color again. The color data would be thrown out by the camera.
1,086 views & 0 likes for this thread, 5 members have posted to it.
2809 guests, 182 members online
