Thread started 14 Sep 2007 (Friday) 02:18
I was wrong-I do need UV filters..advice please
Ben ­ Daniels
Sep 14, 2007 02:18 |  #1
Hi,
In the last few months I have bought a 70-200F4 L IS, and the 100mm 2.8 Macro lense.
I decided at the time not to buy UV filters as I read on some forums that alot of people prefer not to use them, as they might slightly degrade the IQ of the photograph.
But I have little bits of dust etc on both lenses, and as they are expensive and I want to keep them for a few years, I have decided to buy good UV or whatever type of neutral filters so that the front of the lense do not get more dusty than they already are.
So my question is, what are a good make of filter for these lenses?
Any advise is very much appreciated.
Ben
5DMK2 w/Grip: 40D w/Grip: Canon D60: 100mm F2.8 Macro USM : EF17-35mm F2.8
L : EF70-200mm f4L IS : Canon 1.4x Converter II : BG-E2 grip :TC420EX : Tamrac Ex5 bag :Manfrotto 055XPROB:Lee Filter System
mellowd
Sep 14, 2007 02:20 |  #2
Hoya pro's are good
5D : 17-40L : 85 f1.8 : 135L f2.0L - Full Gear List Here!
Woolburr
Rest in peace old friend.
Gallery: 115 photos
Sep 14, 2007 02:52 |  #3
It really is ok to clean the lens. I have some FD series lenses that have been in service since the early 70's....the glass still looks like new...and no filters other than those required for special effects.
A rocket blower will remove all but the most stubborn dust from the glass...a lens brush will remove virtually everything else...follow up with an occasional swab with a pre-moistened lens tissue and you are good to go for ages.
rklepper
Dignity-Esteem-Compassion
Joined Dec 2003
Sep 14, 2007 06:16 |  #4
Although I do not use them all the time, I would only recommend B+W or Heliopan. And make sure that they are multi-coated.
Doc Klepper in the USA
I
Kuma
Sep 14, 2007 06:25 as a reply to  @ rklepper's post |  #5
Dust gets everywhere. If you have a few specks on the outside of your lens I wouldn't worry about it. They are so far out of the focal plane that its not going to effect images. Eventually dust will get inside lenses and cameras so I wouldn't worry about it. Invest in a rocket blower and get some lens cleaning supplies (good ones).
B+W (brass rings) and Heliopan are highly regarded. A lot of people on the foums buy from Hvstar who tend to have the best prices around although they are in Hong Kong.
GL :D
SkipD
Joined Dec 2002
Sep 14, 2007 06:33 |  #6
Woolburr wrote in post #3927120 (external link)
Ditto.
All of my 1960's lenses are still in virtually pristine condition (except for the worn external finish), and none has ever worn a filter for anything but special effect.
All of my lenses are used with a properly designed (for the individual lens) rigid lens hood. The lens hoods provide protection against stray light causing flare and they provide a lot of mechanical protection for the lens.
Dust is easy to remove from a lens. As mentioned above, a blower is all that is necessary 90(+)% of the time, and properly used lens tissue and cleaning fluid takes care of the rest.
Skip Douglas
Ben ­ Daniels
Sep 14, 2007 08:26 |  #7
Ok, thanks alot for the information everyone.
It seems as if you have saved me some money :-)
Have a good weekend!
_aravena
Sep 14, 2007 09:02 |  #8
Dust will either be on your lens or be on the filter. I wouldn't get a filter for that reason. To protect the glass from something worse then yes. Which is why I have filters on mine. i even used a filter on my rented 100-400L. Just took it off the 10-20 for the time being since I wasn't going to use it that much.
It's just good extra protection I believe. Especially since I was shooting concerts and well it's crowded and you don't know what you'll be bumping into.
Last Shot Photography
Gadgetholic
Sep 14, 2007 09:58 as a reply to  @ _aravena's post |  #9
Have a read of this http://www.the-digital-picture.com/Reviews/B+​W-UV-Filter.aspx (external link)
1DS MKII, 30D
10-22, 50 f/1.4, 24-105 f/4
L
100 f/2.8 Macro, 70-200 f/2.8
L IS
16-35 f2.8
L II, 24-70 f2.8L
1.4TC, 580EX, BG-E2
Jon
Joined Jun 2004
Sep 14, 2007 11:58 |  #10
I use B+W MRC multicoated filters on all my lenses. Other reliable brands are Heliopan's SH-PMC and Hoya's S-HMC or better.There's a Filter FAQ which has an even-handed treatment of the pros and cons as well.
Jon
Cocker Spaniels
canonpink
Sep 14, 2007 12:00 |  #11
Ben Daniels wrote in post #3927025 (external link)
Hi,
Ben
Do you mean you have dust inside the lens, or on the lens? There is a big difference.
CP
No signature, but a bunch of gear.
Mark_Cohran
Joined Jul 2002
Sep 14, 2007 12:05 |  #12
canonpink wrote in post #3929490 (external link)
Actually, in terms of IQ, there's not. Even a few specs dust inside the lens isn't going to affect IQ.
Mark
Mark
Some primes, some zooms, some Ls, some bodies and they all play nice together.
Forty years of shooting and still learning.
My Twitter (external link) (NSFW)
Follow Me on Instagram (external link)
airfrogusmc
Gallery: 179 photos
Sep 14, 2007 12:07 |  #13
^^^^^ What he said. I have a 55 1.2 Aspherical from the 1970s and the glass (front element) is like new. Dust is a constant problem,
Jethro790
Sep 14, 2007 13:10 as a reply to  @ airfrogusmc's post |  #14
Rocket blower and lens brush for me. No flters unless it's a polarizing...
If you must know...
MaxxuM
Sep 14, 2007 13:42 |  #15
Hi,
Ben
You might want to take a look at some tests I did with the HOYA UV filter... The only time I'll put it on is when conditions are really bad... I'm going to do tests with the "Protective" (just glass) version of this filter this weekend to see how it does.
https://photography-on-the.net/forum/showthre​ad.php?t=362150
2,603 views & 0 likes for this thread, 16 members have posted to it.
861 guests, 133 members online
